idle control mal fnction. What could it be?
Old Aug 19, 2007 | 01:07 PM
HAZARD_1310's Avatar
Default idle control mal fnction. What could it be?
well I don't know what to fix so this code won't show up in my check engine?
Old Aug 19, 2007 | 02:46 PM
slowcivic2k's Avatar
Default Re: idle control mal fnction. What could it be? (HAZARD_1310)
Might want to tell us what the code is first, and some symptoms...
https://honda-tech.com/zerothread/1901557
Old Aug 20, 2007 | 02:48 PM
Default Re: idle control mal fnction. What could it be? (slowcivic2k)
This is the code well one of them, so the car doesn't responds how it sopposed to when I accelarate the intake makes more noise but the car moves the same.
Any ideas on what could it be?
P0505 Idle Control System Malfunction
Old Aug 20, 2007 | 02:50 PM
phootbag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAZARD_1310 &raquo;</TD></TR><TR><TD CLASS="quote">This is the code well one of them, so the car doesn't responds how it sopposed to when I accelarate the intake makes more noise but the car moves the same.
Check for an intake leak.
Old Aug 20, 2007 | 03:16 PM
wiZCo's Avatar
Stouts 'n' Scotch
If this is referring to the IACV, take it off, clean it and see if it fixes the problem. if it doesn't, you'll need a new one.
This is assuming you're throwing a code 14....
Old Aug 20, 2007 | 03:21 PM
Default Re: idle control mal fnction. What could it be? (phootbag)
no, I checked for leaks theres none, or at least I don't think there is. I'll double check dough.
It feels really slow I have to shift down to keep up with regular drivers.
Any other ideas on what could cause this?
I also have these 2 other codes but I thought that could be the main cause.
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0325 Knock Sensor Circuit Malfunction
Old Aug 20, 2007 | 03:22 PM
I tried it but its the same.
Old Aug 20, 2007 | 04:59 PM
phootbag's Avatar
Are there signs of rodents in your engine compartment? They can cause some serious problems.
Old Aug 21, 2007 | 07:59 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (ShortyzKustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortyzKustomz &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to jack this thread. But Im new to Hondas and instead of startin a new topic, where is the IACV and how do you clean it</TD></TR></TABLE>
You could've searched. Don't thread jack. The location depends on your engine.
jewpont
13
Dec 18, 2007 07:54 AM
piotrush
Oct 7, 2006 01:38 PM
lowcivex
May 22, 2003 09:16 AM
