idle control mal fnction. What could it be?
Re: idle control mal fnction. What could it be? (HAZARD_1310)
Might want to tell us what the code is first, and some symptoms...
https://honda-tech.com/zerothread/1901557
Re: idle control mal fnction. What could it be? (slowcivic2k)
This is the code well one of them, so the car doesn't responds how it sopposed to when I accelarate the intake makes more noise but the car moves the same.
Any ideas on what could it be?
P0505 Idle Control System Malfunction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAZARD_1310 »</TD></TR><TR><TD CLASS="quote">This is the code well one of them, so the car doesn't responds how it sopposed to when I accelarate the intake makes more noise but the car moves the same.
Check for an intake leak.
Stouts 'n' Scotch
If this is referring to the IACV, take it off, clean it and see if it fixes the problem. if it doesn't, you'll need a new one.
This is assuming you're throwing a code 14....
Re: idle control mal fnction. What could it be? (phootbag)
no, I checked for leaks theres none, or at least I don't think there is. I'll double check dough.
It feels really slow I have to shift down to keep up with regular drivers.
Any other ideas on what could cause this?
I also have these 2 other codes but I thought that could be the main cause.
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0325 Knock Sensor Circuit Malfunction
Stouts 'n' Scotch
Re: (ShortyzKustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortyzKustomz »</TD></TR><TR><TD CLASS="quote">Sorry to jack this thread. But Im new to Hondas and instead of startin a new topic, where is the IACV and how do you clean it</TD></TR></TABLE>
You could've searched. Don't thread jack. The location depends on your engine.
