Stumped!! Electrical Problem. I think...
Old Aug 19, 2007 | 12:56 PM
5poonhatch's Avatar
Default Stumped!! Electrical Problem. I think...
So my car is dead. Literally. When i turn my key NOTHING turn on. Not my head lights, inside car light, brake light nothing works and my car doesnt start. Its not a dead battery cuz i checked it already. I basically dont know what to do. Does anyone have any ideas of what the problem can be. Not my ecu, not any fuses, not even the relays. Any suggestions?
Old Aug 19, 2007 | 12:58 PM
xXSilentScreamXx's Avatar
Default Re: Stumped!! Electrical Problem. I think... (5poonhatch)
check your fuses
Old Aug 19, 2007 | 12:59 PM
bart2546's Avatar
Default Re: Stumped!! Electrical Problem. I think... (xXSilentScreamXx)
Might be a main relay, what did you check with the relays to prove that they aren't bad?
Old Aug 19, 2007 | 01:15 PM
92gs...92dx's Avatar
Definately sounds like a fuse or a relay to me... maybe you should double check?
Old Aug 19, 2007 | 05:39 PM
5poonhatch's Avatar
Ill double check. But what fuse or relay can control the whole electrical system?
Old Aug 19, 2007 | 06:01 PM
5poonhatch's Avatar
Default Re: (5poonhatch)
Car doesnt even crank
Old Aug 19, 2007 | 06:46 PM
gsrhatch2356's Avatar
if the headlights dont come on then it is deffintly nothing engine wise. I would look at the battery ground if you are positive it is not the battery. the best way to tell if the ground is bad is take your multimeter and hold your black lead on negitive post of battery and then red lead on ground cable. if you see any voltage at all the ground is bad. and if it was a pgmfi main relay then more often then not the dash lights would all light up but normally when the chk eng light goes off it wont or it wont come on at all.
Old Aug 19, 2007 | 07:25 PM
ic's Avatar
ic
Default Re: (gsrhatch2356)
wiggle your battery cables.
1990GSB18a1
Sep 22, 2012 06:06 PM
Osbjoey
Aug 7, 2012 04:30 PM
billyfiction
Oct 7, 2007 04:03 AM
90Integra
Aug 6, 2006 01:01 PM
fillup
Audio / Security / Video
Aug 12, 2005 04:45 PM
