Recurring Electrical Problem
Old Aug 12, 2005 | 12:00 PM
fillup's Avatar
Default Recurring Electrical Problem
when i turn on my car, and just let it idle for about 15-30 minutes. Then turn it off, it will not start back up. it needs a jump to start. Now, ive gotten my battery AND alternator checked by autozone and pepboys already. They said everything was ok (well the battery has to be recharged at pepboys). i dont know what else to check for now.
Old Aug 12, 2005 | 04:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: Recurring Electrical Problem (fillup)
Try this, start your car then disconnect the batt., if the car keeps running the alt. is working, to make sure it's not a problem after things warm up, let it run for "15-30 min." then disconnect the batt.
If the motor stops when you disconnect the batt. the alt. is N/G or there is a connection problem, check all the connections, from the alt. to engine bay fuse/relay box and from batt. to fuse/relay box, check batt. to chassis ground and motor/transmission to chassis ground. 94
billyfiction
Oct 7, 2007 04:03 AM
5_Lug_B
Oct 2, 2007 03:14 PM
5poonhatch
Aug 19, 2007 07:25 PM
TurboFryBox
Apr 2, 2003 01:42 AM
Qwikrex
Jul 28, 2002 12:34 PM
