which size cat?
I just got a 2.5 inch JDM 5zigen ProRacer A-SPEC exhaust from Japan. The exhaust is much longer then a US or European exhaust, because they run a shorter CAT in Japan.
I just ordered a JDM Honda OEM '98 4-1 Integra-R exhaust manifold also. So now I can run 2.5 inch all true.
Now I need a OBDII cat in the right length to install all the parts. It also need to pass smog in Europe, so is there any info you will need? My car is a 1999 Civic VTI (Ek4) hatch. The VTI model is a European model with is born with a B16a2 engine.
Thanks...
Thanks...
My bad, read that wrong, its early here.
Well, this had happened once to a friends hatch when he got a new exhaust, the cat wasnt the right size. What we ended up doing was making a test pipe for the time being because we couldnt figure solution out. These issues pop up here and there, and the only thing you can do is go to a muffler shop and have them fit a cat in there correctly, they would be able to help you out allot if you are short on idea's at this point.
Hi, I am new from Hong Kong. I have a JDM EG6 directly from Japan (RHD). Sorry for my poor English first. Be attention that if you choose the JDM Honda OEM '98 4-1 Integra-R (DC2R)exhaust manifold. The end of the above manifold is a bigger size screw position that cannot connect to the JDM B16A CAT. Your only choice is to find JDM 98 spec Integra Type-R (DC2R) CAT and the length of the CAT is 30 cm. I know it because I have a same problem. I got the Vision B16A JDM CAT but I cannot place it to the 98 spec Integra Type-R (DC2R) because of the above problem!
Hi EG-HK
So a 30cm cat will fit in between the JDM exhaust and JDM '98 4-1 Integra-R (DC2R)exhaust manifold? It just has to be the right bolt pattern to fit the manifold?
I'm in Europe, and the cat on my car is much longer the a JDM car.
Hi ComCool, all of my exhaust under are JDM so if you use '98 spec 4-1 Integra-R exhaust manifold, it is a must you should have a '98 spec Integra-R CAT, JDM mid pipe and the muffler! I also have that Proracer muffler in my house and now changed the FUJITSUBO(FGK)
If you want to pass the test , you should have a original genuine 98 spec Integra Type-R CAT. But I don't know it will pass or not in Europe and I don't know the Spec of the Europe Type-R!
http://page2.auctions.yahoo.co...81309 (This is the JDM 98 Integra TypeR (DC2R) or Civic TypeR (EK9) High flow CAT)
http://page18.auctions.yahoo.c...88640 (This is the JDM genuine 98 Integra TypeR (DC2R) CAT )
Chong
Dec 13, 2004 06:54 PM
98-0688
Aug 31, 2004 08:12 AM
