HELP ASAP... car just die on me.. #2
Old Aug 18, 2007 | 08:42 AM
JCracer723's Avatar
Default HELP ASAP... car just die on me.. #2
well in my first thread i "we" thought it was the distributor.. i decided to post my last reply to make it easier and get a faster respons.. the thread was getting long...
1995 honda delsol d16z6
well im not getting no spark for sure but its not the distributor fault..
after a good sleep and talking to a friend in the morning, he mention that probably my timing belt was the issue.. at first it didnt make sence to me but after thinking about it for a bit then it made sence..
took the distributor cap off and yep... he was right.. the rotor wasnt turning.. i was like ish ....
took the valve cover off then the upper timing belt off and yep the belt was loose and it was slipping when the engine was cranked..
now the belt didnt come off the pulley nor it was torn.. so my guess is a faulty tensioner???? i gotta take off the crank pulley then the bottom cover to check everything one..
do you guys think that the tensioner went bad? after craking the engine several times.. do you guys think that the valves touched the pistons? do i gotta be worry about anything else?
thanks
Modified by JCracer723 at 6:05 PM 8/18/2007
Old Aug 18, 2007 | 08:55 AM
richi3seg6's Avatar
some people may say yeps...its fucked. Me personaly, i've had many times my car died to to no spark or my auto tensioner took a crap. In the end, my head was still good. So, yes...it is something that will worry you but doesn't need to be checked unless you where racing and then it died. hopefully that helps.
Old Aug 18, 2007 | 10:51 AM
JCracer723's Avatar
Default Re: (richi3seg6)
anyone else?
Old Aug 18, 2007 | 06:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (JCracer723)
The D-series "tensioner" can't really fail. It only does it's job for a second when you first install the timing belt. The spring applies the proper amount of pressure to the belt while you turn the crank pulley a few degrees forward. Once the belt is properly tensioned, the pulley is locked down by torquing the bolt through the middle. Then it shouldn't be able to move ever.
Now if the belt was installed & tensioned without turning the crank a few degrees, it is possible all the slack wasn't removed. Then over time as the belt breaks in, it could slip I suppose. This is all just speculation...
Or perhaps the tensioner pulley wasn't torqued down tight enough, and it slipped...
Old Aug 18, 2007 | 11:35 PM
JCracer723's Avatar
Default Re: (94eg!)
yeah i gotta check this tomorrow.... hopefully i didnt bent any valves..
pinoyboy204
Mar 2, 2010 06:21 AM
vxnine
Jul 26, 2005 09:44 AM
steronz
17
May 2, 2004 08:06 AM
tolowhb
Apr 3, 2004 03:05 PM
navtec
Jun 29, 2003 08:14 AM
