what axles
Old Aug 18, 2007 | 08:38 AM
95civiccpdx's Avatar
Default what axles
what axles should i use for my 95 civic b series swap???
Old Aug 18, 2007 | 09:56 AM
any body i search im going from auto to manual?????????
Old Aug 18, 2007 | 10:13 AM
BlueIntegraBoy's Avatar
Default Re: (95civiccpdx)
94-01 Integra, 99-00 Civic Si, 94-97 Del Sol VTEC
jonathan13's Avatar
get them for whatever motor you plan on putting in.. i used to think all b's were the same but i had an issue with a half shaft that was female and so was the drivers side axle so i had to start the search and found out there are some variations so just stick with the axles from whatever motor you are installing
Old Aug 18, 2007 | 10:16 AM
ke98248's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">94-01 Integra, 99-00 Civic Si, 94-97 Del Sol VTEC</TD></TR></TABLE>
i have a 91 integra motor but 94 trans??
Old Aug 18, 2007 | 10:18 AM
jonathan13's Avatar
go to autozone or whatever your local parts store is and tell them you need axles for a 94 integra ls. and if your car has abs then get abs if not then dont. you should be good to go
Old Aug 18, 2007 | 10:20 AM
alright 1 more ?? will the 91 halfshaft fit with 94 axles or i need a new halfshaft??
Old Aug 18, 2007 | 10:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx &raquo;</TD></TR><TR><TD CLASS="quote">alright 1 more ?? will the 91 halfshaft fit with 94 axles or i need a new halfshaft??</TD></TR></TABLE>
If you have a 91 halfshaft, you will need 90-93 Integra axles.
Old Aug 18, 2007 | 10:25 AM
jonathan13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx &raquo;</TD></TR><TR><TD CLASS="quote">alright 1 more ?? will the 91 halfshaft fit with 94 axles or i need a new halfshaft??</TD></TR></TABLE> forgot to ask if you had a 91 half shaft. i just assumed and that makes an *** out of everyone huh
Old Aug 18, 2007 | 10:26 AM
srry for so many ?? ur helping me alot but will the 90-93 fit my trans or should i just get a new halfshaft
Old Aug 18, 2007 | 11:57 AM
slo_ej8
Mar 17, 2008 08:26 PM
ThoRoughEG6
Nov 16, 2006 11:08 AM
EG6-SIRII
Sep 28, 2005 07:10 AM
handa
Jun 14, 2005 09:00 PM
delsol31603
Jan 21, 2005 10:04 AM
