1st gear,power
I have the same car. Make sure my use every last ounce of power, all the revs, but if you rev past the rev line the car will cut out, so be careful.
VTEC CONTROLLER IS GOOD FOR SHORT DISTANCE POWER.
Turbo it.
Or get custom gears.
Though you couldn't make them much shorter and still have normal daily driving.
Adding intake and exhaust will leave you as fast or slower than you are now.
yah thats what u should do throw a higher rear end in there??? what is he suppose to convert the whole car to rear wheel drive so he can hook up better???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98greensi »</TD></TR><TR><TD CLASS="quote">yah thats what u should do throw a higher rear end in there??? what is he suppose to convert the whole car to rear wheel drive so he can hook up better???</TD></TR></TABLE>
Higher final drive... you know what he meant...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saunders400 »</TD></TR><TR><TD CLASS="quote">I have the same car. Make sure my use every last ounce of power, all the revs, but if you rev past the rev line the car will cut out, so be careful.
VTEC CONTROLLER IS GOOD FOR SHORT DISTANCE POWER.</TD></TR></TABLE>
a vtec controller wont do **** for a mildly modded b16.
b16s have no torque so thats your first problem. id say just boost it and call it a day. 1st and 2nd isnt exactly a hondas sweet spot anyways.
Branman
19
Mar 15, 2006 03:36 PM
