Will a Civic SI Coupe muffler fit on my DX hatch?
Old Aug 18, 2007 | 02:00 AM
Joe Kickass's Avatar
Default Will a Civic SI Coupe muffler fit on my DX hatch?
They look the same other than the outlet pipe being longer. Would it fit if I had the tip cut off?
Thanks!
Old Aug 18, 2007 | 04:23 AM
zoso's Avatar
Default Re: Will a Civic SI Coupe muffler fit on my DX hatch? (Joe Kickass)
They are the same muffler, the only difference is the tip. The si can with a crome tip, all other trim levels didnt have the tip...
Old Aug 18, 2007 | 04:26 AM
Default Re: Will a Civic SI Coupe muffler fit on my DX hatch? (zoso)
Really? Because the outlet pipe does seem longer (regardless of the chrome tip).
Maybe I got an EK muffler? Or are those the same as the EG's?
Old Aug 18, 2007 | 04:59 AM
zoso's Avatar
I dont know about the ek on eg thing but i know that all ej8 mufflers where there same thing, honda just add a crome tip. I have a stock 2000 ex civic muffler forsale if you want it, $20...
Old Aug 18, 2007 | 05:01 AM
heh, I already just bough a muffler which I am not sure will fit. (dumb move, I know).
Old Aug 18, 2007 | 05:21 AM
zoso's Avatar
what muffler did you buy, and what car do you have. It should fit tho. You can get anything to fit. Most likely you will just have to have them cut and weld it right where the muffler starts, nd maybe move the hangers depending on what muffler you use. But that should be like 25 bucks...
RyanA's Avatar
Hatch uses a muffler with a way shorter tailpipe coming from the muffler. You'll need to cut it off to fit or it will stick outabout 8" or so... Put it on, mark it, pull it off and cut, reinstall. If you still have the tip, it's just held on by a 10mm headed set bolt, it can be reinstalled on newly cut pipe...
Old Aug 18, 2007 | 05:26 AM
Default Re: Will a Civic SI Coupe muffler fit on my DX hatch? (RyanA)
Wicked! that's what I was hoping!
And yes mine is a 92 DX hatch. The muffler is from an Si coupe
Old Aug 18, 2007 | 11:42 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoso &raquo;</TD></TR><TR><TD CLASS="quote">They are the same muffler, the only difference is the tip. The si can with a crome tip, all other trim levels didnt have the tip...</TD></TR></TABLE>
The tip was actually an option for other trims too.
I'm not sure how well a '99-'00 Si coupe muffler will fit on a '92 DX hatch though.
Old Aug 18, 2007 | 09:56 PM
Default Re: Will a Civic SI Coupe muffler fit on my DX hatch? (NOFX)
:S
Man I hope it's from and EG hehe.
Old Aug 18, 2007 | 10:42 PM
EJ6JON's Avatar
hmmm maybe!
Old Aug 19, 2007 | 01:43 AM
Mashimaro's Avatar
Default Re: (Jsk20R)
it could fit if you cut off at least 8" from the flange before the piping enters the muffler section.
i tried to save my Apexi WS from my coupe for my hatch, but it still didn't fit in the end. rattlled really bad. not really worth trying to make that coupe muffler fit onto the hatch for how much trouble it'll be...
r1ch1e
Dec 6, 2007 06:51 AM
Libertariat
Apr 26, 2007 11:34 AM
fsufreak08
Apr 22, 2007 09:36 AM
be.twenty
Jul 11, 2005 07:13 AM
