harder pedal feel... symptoms?
i had a stage 3, 6 puck on my LS trans, with a lightened flywheel . my j1 trans has a findanza (spelling) flywheel and an "organic" clutch (clutch/flywheel came with they trans)
after i swapped trans.... ys1/ls to my XSi-j1 trans no lsd the pedal is gradually getting harder... or it could be my imagination
why would my pedal feel harder? i think............................ symptoms please?
the only reason i can think of is something to do with the cable...
the pressure plate on my ls trans was a way more heavy duty plate then one i have now so shouldn't the one i have now be softer...?
thankyou
Modified by rewerbcrx at 11:27 PM 8/23/2007
Modified by rewerbcrx at 11:31 PM 8/23/2007
thankyou
Brand has alot to do with it as well..
For example,I had a stage 3,6 puck F1 clutch kit,and the pedal was as soft or softer then a stock crx.
Yet an exedy stage 1 felt 4x stiffer.
just something to think about.
i actually forgot to grease the shift release fork when i replaced it... the stage 3, 6 puck and flywheel were XTD and i was extremely happy with them... i guess i gotta find out what brand the clutch and pressure plate are in the trans now....
another q:
can i use my clutch setup from my ls trans ( 90 teg) and put it on my j1 trans (90 -91 XSi teg)????????????????
another q:
BrianSi91
Northeast (Sales)
Dec 1, 2008 02:36 PM
