SI just hit 60K Miles what should i do.......
Old Aug 17, 2007 | 07:58 PM
lamboextreme's Avatar
Default SI just hit 60K Miles what should i do.......
well i bought my car (00 Si) when it had 55,000 Mi and i just hit 60,000, and i don't know what the previous owner did in terms of scheduled maintanance. I'm going to change the air filter becuase it's dirty, fuel filter, spark plugs and wires. my question is if i'm missing anything that i should do just to keep the car in good shape, should i change the timing belt? also i have I/H/E and CTR cams what kind of spark plugs and wires should i get for the best performance or should i just get stock . thanks.
Old Aug 17, 2007 | 08:01 PM
sk8shorty012's Avatar
1) flush the cooling system
2) adjust your e-brake
Old Aug 17, 2007 | 08:07 PM
94hondacivicvtec's Avatar
Default Re: SI just hit 60K Miles what should i do....... (lamboextreme)
stock spark plugs, stock wires, cap and rotor, oil change (with filter), fuel filter, timing belt, air filter, tranny oil change, belts if needed, ajust valve lash, make sure the intake manifold and throttle body is clean and flush the coolant system (make sure you run the heater. don't buy any special spark plugs or wires, there not going to net you any more power. GL
Old Aug 17, 2007 | 08:13 PM
HarfordCTR's Avatar
Default Re: SI just hit 60K Miles what should i do....... (94hondacivicvtec)
Change you trans fluid, just get stock plug wires, and maybe some ngk Platinums
Old Aug 17, 2007 | 08:15 PM
EG6 Love's Avatar
call a honda dealer and ask them wat kind of stuff they would do at that milage... then jus do it ur self
Old Aug 17, 2007 | 08:20 PM
Default Re: SI just hit 60K Miles what should i do....... (HarfordCTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarfordCTR &raquo;</TD></TR><TR><TD CLASS="quote"> ngk Platinums</TD></TR></TABLE>
Old Aug 17, 2007 | 08:30 PM
NOFX's Avatar
H-T White Ops
https://honda-tech.com/zerothread?id=2053807
Old Aug 17, 2007 | 09:13 PM
Default Re: (NOFX)
Old Aug 17, 2007 | 09:34 PM
smileycvc's Avatar
Default Re: (lamboextreme)
You dont need to change the timing belt for another 40k.
Old Aug 17, 2007 | 09:41 PM
RiceOrRocket's Avatar
just get some ngk plug and wires, flush the coolant system, replace air/fuel filter, check belts, check valve clearances, and enjoy having a low mileage whip.
Oh i pretty much copied what everyone else said. haha lol
Old Aug 17, 2007 | 09:42 PM
Default Re: (smileycvc)
is there any way of knowing if the belt needs to be replaced?
Old Aug 17, 2007 | 10:10 PM
HiProfile's Avatar
If you have a I/H/E & cams, I'm assuming you have a tuned EMS? If not, that would be the next step. Running too lean will kill your plugs, stress your motor, heat your header up much more than normal, and possibly burn your valves.
Running a tuned car will last you more miles than an untuned car with a basic tune-up.
Old Aug 17, 2007 | 11:49 PM
Boost_V's Avatar
Default Re: SI just hit 60K Miles what should i do....... (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamboextreme &raquo;</TD></TR><TR><TD CLASS="quote">is there any way of knowing if the belt needs to be replaced?</TD></TR></TABLE>
examine them to see of any cracking or worn spots. If you look closely, it's not hard to see...that is if they need to be changed.60,000 miles is not a lot, so as long as you take good care of your motor, should run like a champ.
Old Aug 18, 2007 | 09:46 AM
Does anyone know of a good shop that does good tunning in the oceanside area or close by there?
Old Aug 18, 2007 | 11:02 AM
ke98248's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">If you have a I/H/E & cams, I'm assuming you have a tuned EMS? If not, that would be the next step. Running too lean will kill your plugs, stress your motor, heat your header up much more than normal, and possibly burn your valves.
Running a tuned car will last you more miles than an untuned car with a basic tune-up.</TD></TR></TABLE> You don't need to tune your car if your only mods are I/H/E...
Old Aug 18, 2007 | 02:44 PM
he was saying a tune is good for I/H/E+cams. Anytime you mess with the stoke of the valvetrain you should get someone to tune it.
If its just I/H/E no tune needed.
Old Aug 18, 2007 | 05:30 PM
Default Re: (RiceOrRocket)
i have I/H/E CTR cams and AEM camgears. the owner said the camgears where in stock setting.
Old Aug 18, 2007 | 07:51 PM
b16a3delsol's Avatar
do just a basic tune up. change plugs, wires, and change the fluids. it cant hurt it.
Tuesdaynightfever
May 4, 2008 10:01 AM
EF4lyfe
Sep 27, 2004 03:59 PM
ieatrice
13
Jan 27, 2004 12:02 PM
VtechMixedKorean
Dec 28, 2002 01:11 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
