Idle (HELP)
hey i have a 93 eg hatch and when i put the a/c on (dosnt blow cold) the motor starts to rev up and down right now i have a d16y7 (converted to obd1) and i have NO CEL's what could this be?
(sometimes it does it when a/c off aswell but not as lound and bad)
um when the car is stoped but on its fine but when i turn the a/c on the car just strts to rev up and down and its not the idle casue ive checked that
Probably a vacuum leak. Check all your lines and if you still cannot find the problem, unplug the IACV and adjust your idle to 450rpm and plug it back in.
The A/C probably doesn't blow cold because there is no refrigerant in it. Does the compressor make a "clack" sound when you press the AC button?
If your compressor does not come on like it should when you press the AC button, your idle will increase, since the compressor puts a load on the engine, it will sustain a boosted idle as long as the compressor is running. This could be an increase anywhere from 200 to 500rpm until it turns off, and then a normal idle (750ish rpm) is maintained.
