Does anyone make a fuel line kit from the filter to the fail?
Old Aug 17, 2007 | 07:48 PM
TwoKSiR's Avatar
Default Does anyone make a fuel line kit from the filter to the fail?
If not what fittings do I need to go from the filter to a BDL fuel rail on a 94 Accord with a h22 swap? If it matters it's running a Euro R intake mani with a Rosko Racing kit on it.
Old Aug 17, 2007 | 09:44 PM
Hawkze_2.3's Avatar
Default Re: Does anyone make a fuel line kit from the filter to the fail? (TwoKSiR)
http://Fast-turbo.com can make one for you or give you the info you need.
Edit: I guess they changed their site but I'm sure they still do fuel lines...
Old Aug 17, 2007 | 09:49 PM
TwoKSiR's Avatar
Default Re: Does anyone make a fuel line kit from the filter to the fail? (Hawkze_2.3)
I can make one if someone will tell me what fittings i need for the lude.
Old Aug 19, 2007 | 06:07 PM
Rosko's Avatar
the threaded stud in the stock H22 rail is an M12 X 1.25 thread.
easiest way would be to use one of these banjo adapters...
http://www.jegs.com/webapp/wcs...26_-1
it says its for a civic, but the h22 rail also uses the 12mm stud so it should also work for that. then you wil probably do something similiar with the filter end and run -6 line inbetween the two.
the other option would be to find a M12 X 1.25 TO -6 flare adapter, and remove that stud altogether but that may be hard to come by.
Old Aug 29, 2007 | 10:08 PM
TwoKSiR's Avatar
Default Re: Does anyone make a fuel line kit from the filter to the fail? (Rosko)
I need it for a BDL rail.
Old Aug 29, 2007 | 10:11 PM
Rosko's Avatar
ahh then you need a -8 ORB to a -6 FLARE
I'll find one in a sec here...
Old Aug 29, 2007 | 10:24 PM
Rosko's Avatar
Here we go...
http://store.summitracing.com/...w=sku
thats assuming you want to use -6 hose/fuel line (which will be fine)
Old Sep 2, 2007 | 05:46 PM
TwoKSiR's Avatar
ok then i need a -6 to a m12x1.25 adapter to attach the fuel line to the fuel filter? then what do i need to hook up a stock return line to a AEM FPR? It didnt come with a fitting. It's the new style AEM FPR. Thanks.
championshipwhite93si
Mar 6, 2007 04:21 PM
KoRE
Mar 10, 2004 07:03 AM
98HB
Mar 25, 2003 02:37 PM
rOby
Sep 10, 2002 07:48 PM
