radiator cap leak bubble and upper hose blown
well ok this is on my moms car and im allittle stumped. car does NOT over heat. a few weeks ago the upper radiator hose blew, so i changed it out for her and when i started the car and let it warm up ect i noticed a fizzing sound coming from the cap with bubbles coming out of the cap. so i thought maybe the cap wasnt allowing the system to discharge pressure correctly so i swapped it out with a new oem cap. now today i change her oil for her and i notice the same fizzing and bubbling ..... does anyone have any idea whats going on??
theres a fizz candy lodged in the radiator.....jk under the radiator cap there should be a lil attachment on there . make sure it still has it. On my car I had sorta the same problem, and I went thru two of those Oem caps bak to bak til finally i got lucky i guess n that lil peice dint brake off.... Also check for cracks, maybe wana replace other hoses, um, thats my 2cents.
h thanks ill check ii .... im just wondering like i said if its fizzing bc the pressure is some built up .... would explain why the hose blew earlier as well
bump for more input
bump for more input
robbys89
May 13, 2009 12:02 PM
nonvtec92
Jan 22, 2009 08:19 AM
