d15 engine knocking
Old Aug 17, 2007 | 03:21 PM
mizzoEG's Avatar
Default d15 engine knocking
thanks for reading, i cant seem to figure out my problem so i thought maybe i can get some pointers.
every time i start my 94 civic hatch w/ d15b7 i hear knocking possibly from my lower block (where i believe the noise is coming from) and when i accelerate i hear it louder. after driving for five minutes or so it seems to go away, and if i drive my car soon again i wont hear it, only when the car sits for hours until i start it i'll hear the knocking. any idea guys? thanks.
Old Aug 17, 2007 | 03:25 PM
crxricer66's Avatar
Default Re: d15 engine knocking (mizzoEG)
mine did the same exact thing, and still does it. it seams to happen when its colder outside. it has always done it and i dont think its anything to worry about. i owned it for over a year and it was ran pretty hard. never bothered it.
Old Aug 17, 2007 | 03:29 PM
sageuvagony's Avatar
You're sure it's from the block and not the head right? Mine makes noise in cold weather but goes away when warm. Here's 2 vids showing what I mean.. And how's your oil by the way?
http://www.youtube.com/watch?v=cKHjJxw9HJY
http://www.youtube.com/watch?v=EgdwcO4V55Q
Old Aug 17, 2007 | 03:54 PM
mizzoEG's Avatar
i have a slight oil leak from under my engine, nothing serious, it seems to be my oil pan gasket but other then that the oil is pretty fine.
the thing is, is that im in chicago and its no where near cold right now and i havent been through a winter with my car yet.
the noise in the videos from your d16 didnt quite resemble the ticking my engine makes sageuvagony, any other ideas?
Old Aug 17, 2007 | 04:00 PM
leroyb's Avatar
i had that problem too so one day i down shifted in the freeway and my motor blew
Old Aug 17, 2007 | 04:05 PM
Lasty K's Avatar
I had knock also, ended up in conclusion that I spun a bearing due to low oil and blew my motor later in a few days.
Old Aug 18, 2007 | 01:07 PM
mizzoEG's Avatar
i got an automatic trans, but anyways what should i do?
Old Aug 18, 2007 | 01:12 PM
schardbody's Avatar
so is it ticking or knocking??? bottom end knock isnt just going to go away once the engine is warm.
Old Aug 18, 2007 | 01:19 PM
mizzoEG's Avatar
Default Re: (schardbody)
im not positive whether it is knocking or ticking but from my best guess it sounds like a ticking
Old Aug 18, 2007 | 04:30 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (mizzoEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">im not positive whether it is knocking or ticking but from my best guess it sounds like a ticking</TD></TR></TABLE>
Ticking is usually just valve chatter, especially if it goes away once the engine is warm. Try doing a valve lash adjustment.
Old Aug 18, 2007 | 07:56 PM
jdmracer12's Avatar
the injectors are pretty loud in hondas as well. they make a ticking noise.
Old Aug 18, 2007 | 08:16 PM
hmtcrxsir's Avatar
Default Re: (jdmracer12)
sounds like you spun a bearing
Old Aug 18, 2007 | 09:45 PM
mizzoEG's Avatar
thanks for the info guys.
if the ticking is possibly coming from the fuel injectors should i replace them? is it costly?
and what is valve lash adjustment?
Old Aug 19, 2007 | 07:29 AM
schardbody's Avatar
Default Re: (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you spun a bearing</TD></TR></TABLE>
haha, not even close to being possible, a spun bearing will be a VERY pronounced KNOCK, not a tick, and it wont go away when the engine is warmed up.
Old Aug 19, 2007 | 08:06 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info guys.
and what is valve lash adjustment?</TD></TR></TABLE>
You shouldn't replace the fuel injectors, they're just loud in some motors, it's not an issue. I'm still pretty certain that you need a valve lash adjustment. It's the process of adjusting the valve clearances. If you don't want to try doing it, most shops can do it for $50-$75.
Old Aug 19, 2007 | 08:10 AM
ShortyzKustomz's Avatar
Adjusting valves isnt a big deal, get a feeler guage from Sears for a few bucks get amanual for your car that has the valve adjustment procedure and go at it
Old Nov 27, 2013 | 05:39 AM
l3racl's Avatar
I had the same exact problem with my d15b2 it would kinda "rattle" and later in a about 6 months it now has a knock after driving it hard.
00zzySi
Oct 8, 2010 11:27 AM
markturbo
Honda Civic (2006 - 2015)
Mar 31, 2009 11:55 AM
slowassciv33
Sep 12, 2006 12:25 PM
kar_the_terrible
Sep 5, 2004 06:56 PM
PainfulTeg
Sep 10, 2002 09:22 PM
