F20b swap, 97 ex coupe, idle surge
ok, i searched and tried everything i can think of, now i am comin here for advice... iac is disabled, tps is calibrated correctly, no vacume leaks located etc etc. there is no fast idle valve on this tb. its a F20b which is almost identical to the H22. any help or advice is greatly appriciated.
tried a new TB that has all virgin sensors... still does this.????
thanks
-Don
thanks
-Don
fixed idle by putting a plate on the iac location eleminating it.... now car surges with slight pressure applied to throttle but cleans up when wot is achieved???
how can this be fixed???
got the same setup in my 97 ex, anyways i had the same issue when i first put the motor in, i took it to my local honda shop and they replaced the top half of the intake mani with one from an obd1 h22, runs perfect now! i think it has something to do wit the dual butterflies, and now its single so it all works out. i forget the reasoning they told me... hope this helps
****, you got the F20B - like the SIR-II accord motor or whatever?
Drops like 200hp?
F and H - good ****.
I have no help for you though
Drops like 200hp?
jamesd86
Sep 9, 2011 04:32 AM
97ex082391
Apr 21, 2011 07:10 PM
SaLvAcIvIc97
Nov 15, 2007 08:23 AM
