F20b swap, 97 ex coupe, idle surge
Old 08-17-2007, 11:34 AM
sicegcivic's Avatar
Default F20b swap, 97 ex coupe, idle surge
ok, i searched and tried everything i can think of, now i am comin here for advice... iac is disabled, tps is calibrated correctly, no vacume leaks located etc etc. there is no fast idle valve on this tb. its a F20b which is almost identical to the H22. any help or advice is greatly appriciated.
tried a new TB that has all virgin sensors... still does this.????
thanks
-Don
Old 08-17-2007, 05:24 PM
sicegcivic's Avatar
fixed idle by putting a plate on the iac location eleminating it.... now car surges with slight pressure applied to throttle but cleans up when wot is achieved???
how can this be fixed???
Old 08-20-2007, 09:55 AM
PnkRokCountryboy's Avatar
Default Re: (sicegcivic)
bump
Old 08-20-2007, 10:02 AM
ej8_vtec's Avatar
got the same setup in my 97 ex, anyways i had the same issue when i first put the motor in, i took it to my local honda shop and they replaced the top half of the intake mani with one from an obd1 h22, runs perfect now! i think it has something to do wit the dual butterflies, and now its single so it all works out. i forget the reasoning they told me... hope this helps
Old 08-20-2007, 11:11 AM
S2blueeg's Avatar
Default Re: F20b swap, 97 ex coupe, idle surge (sicegcivic)
bump
Old 09-27-2007, 07:40 PM
jdm.ejone's Avatar
Default Re: F20b swap, 97 ex coupe, idle surge (S2blueeg)
hey problem fixed. put on an h22 top half with iacv and calibrated the tps. no more surging
Old 09-27-2007, 09:32 PM
Syndacate's Avatar
Default Re: F20b swap, 97 ex coupe, idle surge (jdm.ejone)
****, you got the F20B - like the SIR-II accord motor or whatever?
Drops like 200hp?
F and H - good ****.
I have no help for you though .
Old 02-16-2024, 03:07 PM
MikeyX77's Avatar
would it be possible to just swap the entire manifold too fix it? Just having a lot of trouble trying too find just the top half of manifold
jamesd86
09-09-2011 04:32 AM
97ex082391
04-21-2011 07:10 PM
SaLvAcIvIc97
11-15-2007 08:23 AM
Quick Reply: F20b swap, 97 ex coupe, idle surge
