Oil catch can
Old Jun 12, 2002 | 10:00 PM
xtrafastcivic's Avatar
Default Oil catch can
Should i install the lines to the pcv lines or the vavle cover to intake lines?? everybody says the other and i'm confused
Old Jun 12, 2002 | 11:18 PM
sparkz's Avatar
Default Re: Oil catch can (XtraFastCRX)
what kind of motor do you have? if you already have the seperator box, then you install the catch can inline between the box and the intake manifold.
Old Jun 13, 2002 | 01:21 AM
Xsi's Avatar
Xsi
Default Re: Oil catch can (sparkz)
I'm confused too, I always thought it was the PCV line but I keep seeing people with it on their Valvecover line. I have a B16A
Old Jun 13, 2002 | 02:02 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Oil catch can (Xsi)
"Both" lines are suppose to be going to the catch can. Otherwise, you are still getting those nasties spewed into the intake...
[Modified by 88_SC_CRX_Si, 3:03 AM 6/13/2002]
Old Jun 13, 2002 | 06:53 AM
BSQ's Avatar
BSQ
The oil catch can should be hooked up between the PCV valve and the intake manifold. The reason being, is because this the route that recirulated BLOW-BY VAPORS (and oil vapor droplets) back into the intake manifold. The BREATHER HOSE routes FRESH AIR to the crankcase. Here is a diagram which illustrates this.
Larger image (may have to cut and paste): http://www.imagestation.com/picture/...d.gif.orig.gif
Here is another diagram which shows the oil catch can hookup.
Old Jun 13, 2002 | 09:34 AM
GruvyTune's Avatar
New User
Default Re: Oil catch can (BSQ)
i took a greddy catch can (about $60 bucks) and filled it with Choreboy copper brillo stuff to act as a baffle to condense oil vapors. Put it inline between my pcv and the intake manifold. Just stuck a breather filter on my valve cover (never see oil coming from there anyway).
Old Jun 14, 2002 | 08:03 PM
Jeff C's Avatar
Default Re: Oil catch can (GruvyTune)
check this link out...
http://www.geocities.com/bretq/DIY_O...tructions.html
Old Jun 15, 2002 | 02:31 AM
Lyonel's Avatar
http://www.c-speedracing.com/howto/c.../catchcan.html
NA JDM GSR
Oct 17, 2006 08:31 PM
self_made
Oct 21, 2002 04:06 PM
rainforest
Jan 5, 2002 07:43 AM
speedjunkeez
Sep 30, 2001 02:50 PM
speedjunkeez
Sep 28, 2001 11:35 PM
