help with cluster.
Old Aug 17, 2007 | 08:56 AM
mugencivic94's Avatar
Default help with cluster.
Im in the middle of trying to put a 95 gsr cluster in my eg. i wired it according to a diagram i found in the archives. but the cluster or dimmer is not comming on. so there is no light to the cluster ive messed with the dimmer and tracked all the wires im in the middle of doing a swap so i can really see if the tach and speedo and fuel are working properly but the turn signals and highbeams and stuff work . what wires and what do i need to check? i plugged the old cluster in and it works so i know its not a fuse or something
Old Aug 17, 2007 | 09:52 AM
anyone? i do know the srs comes on then goes off, the turns and hazards work, the high beam icon comes on, the trunk open light comes on when the trunk is open. as of now i can start the car to check the temp, the tach, and the fuel. any help?
Old Aug 17, 2007 | 09:54 AM
tdizz07's Avatar
Default Re: (mugencivic94)
pm blueintegraboy he is like the cluster god or search some of his archived posts
JaayDeeEmm
Dec 9, 2012 10:47 AM
nevin
Aug 22, 2005 12:11 AM
E-lude78
Jun 5, 2003 01:20 PM
^Sammy]!.
13
Mar 5, 2003 06:09 PM
carlos
10
Oct 15, 2002 08:57 PM
