car wont start
Old Aug 17, 2007 | 08:31 AM
vti444's Avatar
Default car wont start after changing thermostat and fan switch
changed thermostat and fan switch last night and then started engine and let the cooling system bleed, everything was completely normal
went to start car this morning and nothing, doenst crank, absolutley nothing from engine bay but lights on dash come on as usual
never had single problem like this in years ive had car and starts perfect everytime
any suggestions what to check (im guessing maybe a fuse blew but very wierd)
car is 97 ek4
Modified by vti444 at 5:13 PM 8/18/2007
Old Aug 17, 2007 | 08:42 AM
kbouchard1092's Avatar
Default Re: car wont start (vti444)
you didnt take off that ground wire on the thermostat housing did you? when you changed the thermostat???
Old Aug 17, 2007 | 08:49 AM
crazyguy's Avatar
could be your starter or main relay.i had the same problem months ago with all the lights on the cluster but got nothing from engine bay.i checked the main relay and it was find.so unplug the starter and plugged it back and the car started.so i know the starter was bad.
Old Aug 17, 2007 | 09:45 AM
vti444's Avatar
i did remove the ground but was put back
regards main relay, is this the 1 in fuse box in right hand corner of engine bay ?
any pics of of what im looking for with the starter plug ? should i just unplug and plug back in, exactly what am i checking
Old Aug 18, 2007 | 12:23 AM
vti444's Avatar
Default Re: (vti444)
car is still dead, checked for loose connections but all appears ok
any other specific fuse under dash likely to be cause ?
Old Aug 18, 2007 | 08:15 AM
vti444's Avatar
all fuses now checked and fine, cleaned thermostat earth just to be safe but still nothing, tried jump start but no luck
getting desperate now
Brady Stone
Jan 19, 2016 03:40 AM
jimmy051702
Jul 9, 2011 04:32 PM
hell_sol
10
May 11, 2011 02:10 PM
JDC2TypeR
Feb 4, 2008 10:53 AM
lewsscroos_
Sep 27, 2005 12:36 PM
