Transmission Synchros
Old Aug 17, 2007 | 08:29 AM
honda_mike's Avatar
Default Transmission Synchros
Hey, I have an integra LS transmission in my car, my 3rd gear has gone and i found a set of 94+ integra GSR transmission synchros, will the gsr synchros fit my LS tranny and also how would I know if the synchros are good or not ? i found them for a cheap price but I dont know how to check if its good or not, will the teeth on the synchro show me ?
just by the pictures do these synchros look well ... still trying to find out if it will fit my 94+ LS tranny
Modified by honda_mike at 9:47 AM 8/17/2007
Old Aug 17, 2007 | 08:57 AM
Gearspeed-Performance's Avatar
Default Re: Transmission Synchros (honda_mike)
No the 2nd, 3rd and 4th gear synchros are completely different. If you have a grind check the Sleeve, Hub and Gear....those are usually worn and common with a grinding transmission.
Good luck!
Old Aug 17, 2007 | 08:58 AM
honda_mike's Avatar
Alright thanks alot for the help! It's not a grinding the gear just pops out and when i punch it in 3rd I get a bit of a grind ... if i double clutch the 3rd gear will go in.
Will the 90-93 LS Cable tranny syncros fit my 94+LS Hydro transmission?
Old Aug 17, 2007 | 09:16 AM
Default Re: (honda_mike)
Only 92-93 YS-1 LS transmissions.....Cable S-1 or A-1 will not fit.
Old Aug 18, 2007 | 12:49 AM
OC Geezer's Avatar
Default Re: (GearSpeedEF7)
Cable and Hyrdo, two different things.
Why not just go with the synchros made for your car? Might take a little searching but at least you know that it's meant for that part.
Old Aug 19, 2007 | 04:25 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_mike &raquo;</TD></TR><TR><TD CLASS="quote">Alright thanks alot for the help! It's not a grinding the gear just pops out and when i punch it in 3rd I get a bit of a grind ... if i double clutch the 3rd gear will go in.
Have you checked the shift forks for wear and straightness?
Old Aug 19, 2007 | 11:01 AM
slowcivic2k's Avatar
Is the case apart? Take a look at the bearings, a clearance in the shafts will cause them to move, in this case the mainshaft will thrust into the ISB on acceleration. If the clearance is big enough, it will make the shift to 3rd longer, resulting in a pop out and grind.
What GearSpeedEF7 is normally the case, it will tear up everything else, except the synchro ring.
Old Aug 19, 2007 | 11:27 PM
Mista Bone's Avatar
D Tranny Guru
Weird, we all agree
vtec4max
Jul 30, 2007 07:40 AM
TealEG!
Apr 27, 2006 10:05 AM
goose21
Nov 27, 2005 02:42 PM
fangtl
Oct 4, 2003 06:19 PM
