whats is the thread pitch of fuel filter inlet??? for a 6an fitting
i recently purchased a fuel line to go from my aem fuel rail to fuel filter. however the adapter which screws into the fuel filter snapped cause it was aluminum and i tightened it too much. i know its an 6an fitting but not sure to what npt size? ive purchased a 6an-1/4npt too big then i returened it for a 6an- 1/8 and was too small. i need to know what size the correct adapter is so i can order the correct one. Thanks!
so what do you think i should tourque this adapter too?? its aluminum and snapped pretty easily and they do not make an steel adapter in that size
True its aluminum, but its not that easy to break. You had to either be going in at an angle or way over torqued it. Just let it sit correctly with the o ring and your set.
hehe yeh i made that mistake a long time ago also.
I normally go with hand tight, or till the threads are set... then no more than 1/4 turn
civbeater90
Aug 27, 2002 09:00 AM
