what the hell its over heating!!! :s
Old Aug 16, 2007 | 05:57 PM
rice a roni's Avatar
Default what the hell its over heating!!! :s
well it didnt over heat on the highway a while ago when i had the engine rebuilt but then i decided to switch to an eg radiator and this was the first time starting it up...i think i let it idle for 10-15 minutes while i was scrubbing dust off the windshield then i took it for a drive around the block since its been sitting forever.
it didnt start over heating until i put it back into the garage then i noticed it was 3/4 ways up the gauge. my fan doesnt come on and the thermostat and headgasket is new. maybe make the fan work? any ideas?
Old Aug 16, 2007 | 09:28 PM
crazykamper's Avatar
how do you get the air outa system??? i didnt replace minewith eg, i still have my stock fan/rad... just when i put my motor back in, ever since, my fan dont go on, and it starts to overheat after sitting for little....
Old Aug 16, 2007 | 09:30 PM
Jdmhonda26's Avatar
Default Re: what the hell its over heating!!! :s (rice a roni)
wut kinda car do u have? an there shoud be a fan on/off switch located sumwere on ur dash..cause my honda has sumin like that
Old Aug 18, 2007 | 12:48 PM
Default Re: what the hell its over heating!!! :s (Jdmhonda26)
really? i didnt really know hondas have an on/off switch for the coolant fan, mind showing a picture?? oh i figured it out now...the thermostat works and the head gasket is ok...i think my fan is just dead and so then it over heats if it sits for a while...
but yeah lets see that fan on/off switch.
Old Aug 18, 2007 | 04:41 PM
burnout8488's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmhonda26 &raquo;</TD></TR><TR><TD CLASS="quote">wut kinda car do u have? an there shoud be a fan on/off switch located sumwere on ur dash..cause my honda has sumin like that</TD></TR></TABLE>
rofl, this is ridiculous.
Don't post advice unless its actually valid information!
Old Aug 18, 2007 | 04:47 PM
wiZCo's Avatar
Stouts 'n' Scotch
It's only there because somebody ghetto-rigged it to be that way. No auto manufacturer in their right mind would give drivers the option of turning their coolant fan on/off manually.
OP, if you have a Helms manual, follow their procedure for testing the fan switch, relay and wiring harness. My bet is on it overheating because the fan isn't operating. Another possibility is that there's air in your system.
Old Aug 19, 2007 | 05:54 AM
b20_ed's Avatar
Lol, moving on.......Check ur fan or coolant fan switch. I had a bad fan and relay. The relay is located next to the passenger side headlight.
Shade93
Apr 13, 2010 01:15 PM
omgwtfbbq
12
Sep 24, 2009 06:22 PM
hotcivicsi
19
May 15, 2009 01:54 PM
ATS*Mark
Dec 9, 2003 11:08 PM
