03' MDX Ac problem
hey guys my moms got an 03' mdx with 92,xxx miles on it. recently the ac on higher settings started to make a chattering noise that made me think it was a fan or along those lines, now the newst thing is on the lowest setting a weird looking vapor came out of the vents and im not sure what the problem is
Condensation from the vents are normal. Some people think the dash is on fire buts its just the right temp of the evaporator and ambient temperature along w/ the humidity when you turn the blow on. It happens to my Element every once in a while. As for the noise,is it coming from inside under the right side of the dash or inside the motor area? Could either be debris in the blower motor(kinda sounds like a card in bicycle spokes) or if its inside the engine area,could be a bad fan motor going out.
.hawaii
Aug 7, 2009 11:15 PM
