need help with tire size asap
Old Aug 16, 2007 | 03:40 PM
grandam's Avatar
Default need help with tire size asap
I am wondering what size tires do you guys use on your EK hatches I was looking and it says for, I am wondering is that the correct tire sizes.
1996-195-50-15
1997-195-55-15
Thank you:
Old Aug 16, 2007 | 03:44 PM
t0p_sh0tta's Avatar
Default Re: need help with tire size asap (grandam)
#1 search.
195/55
Old Aug 16, 2007 | 03:46 PM
EGLUVN's Avatar
195/50/15
205/50/15
i would recomend either
Old Aug 16, 2007 | 03:48 PM
98greensi's Avatar
they way it works out with falken tires is that the stock size should be 185/65r14 and with 195/55r15 it's .7 bigger in diamater and a 205/50r15 is .2 of inch smaller in diamater but is wider thats what i'm running on my ej8 and approx, a 2 inch drop i tuck tire and no rubb issues
Old Aug 16, 2007 | 03:49 PM
t0p_sh0tta's Avatar
Default Re: need help with tire size asap (EGLUVN)
195/50 is for the EG chassis, EKs use a slightly taller tire.
Old Aug 16, 2007 | 03:52 PM
grandam's Avatar
Default Re: need help with tire size asap (t0p_sh0tta)
I am wondering what is the difference between the 96 and 97 aren't they the same car, also these will be going on my EK hatch with a 2.5" drop
Old Aug 16, 2007 | 03:54 PM
t0p_sh0tta's Avatar
No difference.
Old Aug 16, 2007 | 04:08 PM
grandam's Avatar
can anyone post pics of there car with the 195-55-15
Old Aug 16, 2007 | 04:42 PM
98greensi's Avatar
this was last year when i was still running 195/55r15
Old Aug 16, 2007 | 05:28 PM
98greensi's Avatar
here's my 205/50r15 on the front and still running 195/55r15 on the rear
Old Aug 17, 2007 | 07:15 PM
grandam's Avatar
Default Re: need help with tire size asap (98greensi)
Hello so I can use the 205-50-15 and there will be know problem what is the difference between the 205-50-25 and the 195-55-15 and also if I use the 205-50-15 will the car be higher off the ground compared to the 195-55-15.
Thank you:
Mark
Old Aug 17, 2007 | 07:23 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandam &raquo;</TD></TR><TR><TD CLASS="quote">Hello so I can use the 205-50-15 and there will be know problem what is the difference between the 205-50-25 and the 195-55-15 and also if I use the 205-50-15 will the car be higher off the ground compared to the 195-55-15.
Thank you:
Mark </TD></TR></TABLE>
Stock tire size is 185/65-14
That's 23.5" total diameter.
205/50-15 has a total diameter of 23.1"
and
195/55-15 has a total diameter of 23.4"
So as you can see, the difference is null. You're comparing 3 or 4 tenths of an inch.
If you were shooting for exactly the same size on a 15" rim 195/55-15 or 205/50-15 would be your best bet
Old Aug 17, 2007 | 07:42 PM
iwantmoreboost's Avatar
Here is a web site that will tell you the over all and how many revs per mile and all the specs http://www.miata.net/garage/tirecalc.html
Old Aug 17, 2007 | 10:08 PM
98greensi's Avatar
with how low my car sits i only have a slight rub issue when there's 4 people in the car when i turn very hard to the right but besides that no complaits and i personaly like the ride quilty better with 205s abit softer and more of a contact patch with road and car will sit a touch lower then stock but not even enough to notice, i just wanted the same diamater of tire or smaller for acclertion
Sleepek24
May 31, 2011 05:07 AM
panchlow
11
Oct 6, 2010 08:57 PM
DIABOLIC8
Jun 22, 2009 10:46 AM
bmwracer316
Aug 15, 2007 08:32 PM
