I need help with a H22a into a 92 prelude.
Old Aug 16, 2007 | 12:44 PM
DRAGWORKS's Avatar
Default I need help with a H22a into a 92 prelude.
Hello. I have the H22a swap in the car. I am wondering about the distributor. Do i use the h22a dist. with the internal coil or do I use the H23 dist. with the external coil. Also are there any other things I should be aware of with the wiring or anything? Thanks before hand for any help!!
Thanks
Alex
Old Aug 16, 2007 | 01:13 PM
Finest's Avatar
Default Re: I need help with a H22a into a 92 prelude. (DRAGWORKS)
Use the H23a1 distributor and external coil.
Old Aug 16, 2007 | 01:14 PM
lude_lover's Avatar
next time search but the h23 dizzy will work on the h22a and you just modify the external coil braket i believe. Yall Si's are prewired for vtec so not too much wiring, but there is some minor wiring to be done
Old Aug 16, 2007 | 01:26 PM
Si Speed's Avatar
Default Re: I need help with a H22a into a 92 prelude. (lude_lover)
93+ Preludes are pre-wired for VTEC because the 92's didn't have H22's, at least not in America.
Old Aug 16, 2007 | 01:34 PM
DRAGWORKS's Avatar
Default Re: I need help with a H22a into a 92 prelude. (si_speed)
ok thanks. I did put the h23 dist. in it but just double checking. I still have to change oil and new coolant so we will see how it goesafter that.
Thanks
Alex
Old Aug 16, 2007 | 05:23 PM
DRAGWORKS's Avatar
well i got everything together started it up and it has very crappy idle and is throwing a map code. I tried a different map sensor and it is still doing the same thing. Any one have any input on where to look to correct this?
Thanks
Alex
NukeeZoid
May 25, 2006 10:15 AM
ramikassab
Dec 6, 2004 02:47 PM
92whiteSi
Aug 11, 2004 08:53 PM
ionic_slim
May 24, 2004 06:37 AM
