Okay, so I'm new here and this is my first time doing an engine swap.
I need some help. I have a 1995 Del Sol SOHC Vtec. I'm doing a swap with a GSR motor... and I'm pretty sure I don't have everything I need.
I need a transmission, motor mounts, etc.
Where can I find these... without throwing too much money out of my pocket?
eBay is not my friend either.. I can't seem to find anything I want or need on there. Maybe it's just me.
Any help is/will be appreciated.
Here you go:
GSR into 92-00 civic
I found it in the FAQ section for you. That place is great for good all-around information. Good luck with your swap
Honda-tech Classifieds, Craigslist, eBay, swapsheets, newspaper, or numerous online sites, but if you're looking to save money i wouldn't resort to this.
As per everything you'll need, there's plenty of info on it already, use the Search function at the top right corner.
the swap is the same as in a 92-95 civic
you will need DOHC shift linkage for a del sol, the integra one won't work.
you can try import auto salvage, they're in n.c. and will likely be a little cheaper to ship.
http://www.importautosalvage.com i think.
search.
search.
http://www.hmotorsonline.com sells complete swaps with everything included. Check with them.
EG-Hatch-CLGS
May 26, 2011 09:19 AM
