hf harness wiring problems with b16
Old Jun 12, 2002 | 07:58 PM
mobrep's Avatar
New User
Default hf wiring problems with b16
alrighty. on the hf harness the injector plugs are not shaped the same as the b16 ones. (see picture: http://mobrep.hondageek.org/swap/hf-...or-diagram.jpg ) also, the plugs for the distributor are shaped differently and are different sizes on each harness. the plug for the altenator is the same and plugged up fine, along with the ground. we solved the injector problem by cutting the hf injector plugs off and rewiring the sir ones on. as for the rest, the wiring colors are different and i dont have a colorcode for them. if anyone has one and could hook me up. thanks in advanced.
also, do you have to rewire the plugs or are they suppost to plug right up? i haven't come across any info that says you have to rewire the plugs thats why i'm asking.
and i've got the hasport subharness so thats part is covered.
background info: the car i got the hf harness out of was a 90 hf crx. the guy i got it from just had the harness laying in the back of the car, and there was no motor in the car. so i just grabbed the harness took it as it was an hf sence it had 4 injector plugs.
[Modified by mobrep, 9:44 AM 6/13/2002]
Old Jun 12, 2002 | 08:24 PM
Griffins_Importuning's Avatar
Default Re: hf harness wiring problems with b16 (mobrep)
what harness are u using..dont use the b16 harness. use your factory crx one....hope it helps
Old Jun 12, 2002 | 08:50 PM
90_Civic_Hatch's Avatar
Default Re: hf harness wiring problems with b16 (Griffins_Importuning)
TTT
free bump for you. I am also curious about some of this.
Old Jun 12, 2002 | 11:10 PM
mobrep's Avatar
New User
Default Re: hf harness wiring problems with b16 (90_Civic_Hatch)
bump
Old Jun 12, 2002 | 11:42 PM
mobrep's Avatar
New User
Default Re: hf wiring problems with b16 (crxhfi)
yeah i thought it was really odd as well. i'll go back and check it out. and see what the block says. what really made me think was that almost none of the plugs are the same. just the plug on the altenator. maybe it isn't even an hf harness? i'll check the block tomorrow.
[Modified by mobrep, 2:44 AM 6/13/2002]
Old Jun 13, 2002 | 09:01 AM
Default Re: hf wiring problems with b16 (mobrep)
bump
Old Jun 13, 2002 | 09:33 AM
WykidEH's Avatar
Hey man, this is Jeramy. . . . . . give a call and I'll come over and take a look at what you have and fix your prob. . . . .ok?
Old Jun 13, 2002 | 06:47 PM
mobrep's Avatar
New User
Default Re: hf wiring problems with b16 (WykidEG)
bump.
jj. message me on aim: mobrep
would like for you to come by sometime tomorrow.
what i think is the problem is the harness is from a different gen honda. maybe a 5gen or 6gen. i'm gona see if the harness will plug up to the firewall of the crx. and check that.
pictures of block/tranny and harness' :
took a few more today. the digital camra sucks i know.
Old Jun 13, 2002 | 11:05 PM
I IMed you on your AIM.......I had a question about the harness you have.
oh yah free bump, in case you needed it
Old Jun 14, 2002 | 01:28 AM
mobrep's Avatar
New User
Default Re: hf wiring problems with b16 (90_Civic_Hatch)
the harness that came attached to the b16 is what i refer to as the sir harness. (the motor accually came out of a teg. but oh well. you get my point)
Old Jun 14, 2002 | 05:21 AM
mobrep's Avatar
New User
bump
Jeramy, if you see this message me on aim. i'm gona call wes later today and see if he still has your number.
Old Jun 14, 2002 | 04:28 PM
mobrep's Avatar
New User
the harness that was in the back of the crx. that i took for an hf haress. is accually a ******* 92-95 dx harness. ******* gay ****. so, thats where the problem was.
Old Jun 15, 2002 | 05:10 PM
that sucks. I aim'ed you with a link you may be interested in. Check it out http://www.acute.f9.co.uk/crx/downloads/downloads.htm <---This is it
Turbo EH2
Sep 28, 2006 09:21 PM
coot_er
Apr 29, 2004 09:28 PM
jedubz
Feb 25, 2004 09:32 PM
EGTeK
May 17, 2003 10:27 AM
mobrep
Jun 14, 2002 04:30 PM
