injector wires
Old Aug 15, 2007 | 08:05 PM
High RPM's Avatar
Default injector wires
Are the stock injector wire harnesses that run from the fuel injectors back to the ECU the same for OBD1 and OBD2? Or are the the same?
I'm especially interested to know about the connection at the ECU, but are they any different at either end?
Old Aug 15, 2007 | 09:36 PM
GSR-TRBO-DA's Avatar
Default Re: injector wires (High RPM)
why? are you thinking of cutting them?
Old Aug 15, 2007 | 10:29 PM
numbnuts22715's Avatar
the injector clip is different, if thats what youre asking.
They have a different plug that connects teh fuel injector to the fuel injector harness.
Im unsure about the end at the ecu
Old Aug 17, 2007 | 12:46 AM
High RPM's Avatar
Default Re: (numbnuts22715)
Well, I'll answer my own question, in case anybody else cares. I found out that "injector wire harness" is just one branch of the engine harness: a $700 part from the Acura dealer (where else would you get it?), so I don't think I'll be snipping any wires on that any time soon.
The engine harness then connects to the cabin harness, which then plugs into the ECU. The plug-in at the ECU is the same, that's what I was worried about, cause I want a new ECU with Hondata.
I did snip the wires at the injectors so I could put in RC Engineering injectors. Now they make adaptor clips so you don't have to cut wires but thay look goofy to me, hanging there, and have the potential to rattle around.
wburke69
Aug 9, 2010 09:19 AM
rad32
Aug 4, 2009 05:24 PM
CARMA_626
Dec 25, 2008 12:24 AM
95JDM
Mar 7, 2008 12:52 PM
BfromSD
Jan 24, 2008 05:50 PM
