ground
does ne one know if a disconnected ground would cause a b16a from starting? How man grounds are there, and where are they?.. My swap is done but won't start. Turns over but won't start (no fuel or spark). Fuel pump doesn't prime (no voltage goin to pump), no spark. Gonna check main relay, Not getting any errors, but check engine light stays on.. Light doesn't even recycle. Just stays on. Could low oil pressure cause this?
my swap is doing the same ****..i feel ya...pisses me off. im bout start hitting the engine with a hammer....please help someone....i was thinking bad ecu. but i havent a clue at this point..
Three of us
, the only difference is I'm getting fuel. I opened the fuel pressure release a bit while cranking the car, and fuel is getting that far. i don't know what the problem is.
Pr0ject93hb
13
Mar 21, 2007 09:39 AM
civicdx92
Jun 25, 2006 05:09 PM
