Performance questions about Maintenance!
Old Jun 12, 2002 | 06:46 PM
Red_Si's Avatar
Default Performance questions about Maintenance!
If I burn about a quart of oil every week and a half, how much hp do you think is lost? If i replace the pistons and rings would this take care of the job and put it back to stock hp or would it be better to buy a new STOCK engine?
I plan on doing a mini-me swap in the future and want to know if this block is salvagable, b/c i can get a good running block for 100, but the pistons w/rings would only cost me about 50-75! let me know what you think!
oh, and are the d16a1 pistons the same as the d16a6's???
[Modified by Red_Si, 3:50 AM 6/13/2002]
Old Jun 12, 2002 | 06:58 PM
FourthGenHatch's Avatar
Default Re: Performance questions about Maintenance! (Red_Si)
Well im sure if you fix whatever is causing the oil to burn it will be good as new.
Old Jun 12, 2002 | 07:01 PM
Red_Si's Avatar
Default Re: Performance questions about Maintenance! (FourthGenHatch)
yea, but what are the chances of it being the rings??? b/c that's what everyone keeps telling me that it is! what else could it be?
Old Jun 12, 2002 | 07:57 PM
the DR.'s Avatar
you should really do some more test before going and just replacing rings and pistons just because alot of people tell you thats what it is,
is there blue smoke coming from your exhaust?... no other visible leaks?... the chances of the problem being rings really depends (how old the engine is, the way you drive.. all kinds of stuff) but do a few test first, compression test, if those results come out too low, then try a wet compression test, that should give you a more definate answer.
Old Jun 13, 2002 | 07:46 AM
Red_Si's Avatar
Default Re: Performance questions about Maintenance! (CIVICtypeS)
Yes it smokes blue. I drive regular but push it sometimes (not to the limit). How do I do a comp. check??? would it be better to just buy the other block that i know runs good?
Old Jun 13, 2002 | 07:37 PM
02WRX's Avatar
check this out for a compression test....
http://www.c-speedracing.com/howto/c.../comptest.html
eric
Old Jun 13, 2002 | 07:52 PM
Soled Out's Avatar
[QUOTE]Yes it smokes blue. QUOTE]
blue smoke= rings
ninesecrx
Mar 5, 2007 04:44 PM
OMG WTF
Feb 19, 2006 11:16 PM
discopotato03
Nov 6, 2004 07:44 AM
ActiveAero
Jan 2, 2004 11:51 AM
vtec.dc2
Sep 28, 2003 12:19 PM
