how to barr a civic with an ls engine???smogg?????
ok i tried to search and didnt find any answers....im about to trade my teg for a 94 civic with a ls engine...how do u barr the engine???
another question....does the car have to be barred to pass smog? if the engine is totally stock...i can go to a smog shop and do the smog and there will be no problems?? or they will ask me wheres the original engine or something like that??
im a noob
on smog and ****..where i lived there are no smog and no barred or no bs like that...
thanks in advance...
hatters suck
and no hatters plz...
im a noob
on smog and ****..where i lived there are no smog and no barred or no bs like that...thanks in advance...
hatters suck
94-95 or newer engine. Check the head and make sure it says 93-94.
stock ECU
stock harness
stock USDM intake manifold
stock Exhaust manifold or CARB certified header
stock Intake or CARB certified intake
All EVAP components as well as all hoses hooked up properly
stock ECU
stock harness
In order to have the smog tech even look at your car you will need a BAR sticker.
Since they try to look for VINs to scan from your car and engine to make sure they match.
To BAR your car you need to make an appointment to a BAR referee which are usually at community colleges or automotive schools.
They check for all the emission control systems on your car and such and do a pretty much a test only smog test.
Costs you 30 bucks per try and 10 bucks for the BAR sticker. if you fail, you get one free try after that. Then you have to pay again if you fail.
check the FAQ or search there are lots of info on how to pass BAR.
yeegsr
Jan 7, 2005 10:02 AM
