Possible short? Maybe? HELP
Old Aug 14, 2007 | 08:54 PM
civicgeek133's Avatar
Default Possible short? Maybe? HELP
Ok so last night as I was driving my car I was making a U turn. While I was turning the passensger side headlight and corner light went off and the rear passenger side turn signal stayed on. With the headlights off or JUST the corner lights on it acts perfectly fine. When turn the headlights on, the passenger side turn signal indicator on the cluster stays on along with the high beam indicator but is slighty dim.
I checked all the bulbs and wiring, everything seems to be fine. I haven't the slightest clue what the problem could be. I would appreciate if someone could chime in. If this helps the car is a 91' hatch with a B16.
TIA
Old Aug 15, 2007 | 05:28 AM
1 Fly SI's Avatar
Default Re: Possible short? Maybe? HELP (civicgeek133)
Bad headlight/turn signal switch maybe.
Old Aug 15, 2007 | 06:04 AM
mahatma's Avatar
Default Re: Possible short? Maybe? HELP (1 Fly SI)
yeah i would pull the stalk out of the steering column and check the switch out.
jerzytatt00
Lighting
Jun 26, 2011 01:48 AM
eghatchfla
11
Jul 1, 2010 06:15 PM
civicgeek133
Aug 15, 2007 10:01 AM
Vardoulika
Sep 9, 2003 04:54 AM
DarkCyde SI
Aug 14, 2003 12:12 AM
