obd2 distributor on obd0 dpfi to mpfi swap
Old Aug 14, 2007 | 02:52 PM
redracer1024's Avatar
Default obd2 distributor on obd0 dpfi to mpfi swap
can i use a obd2 distributor as long as its wired rite 2 do the dpfi to mpfi swap on a 91 crx dx?
Old Aug 14, 2007 | 04:58 PM
Crx Jimmy's Avatar
Default Re: obd2 distributor on obd0 dpfi to mpfi swap (redracer1024)
sure as long as you are using a obd2 or obd1 computer
Old Aug 14, 2007 | 09:55 PM
will this work using the pm6 computer? if not does anybody know why? whats the diffences between a obd0 distributor and the obd2?
Old Aug 14, 2007 | 11:20 PM
up
Old Aug 15, 2007 | 06:02 AM
drdisco69's Avatar
Is a PM6 an OBD2 or OBD1 ecu? No? Then it won't work. The OBD1 and 2 distributors have a 24 tooth crank position sensor, while the OBD0 is 16 teeth.
Old Aug 15, 2007 | 01:39 PM
Default Re: obd2 distributor on obd0 dpfi to mpfi swap (drdisco69)
thank you
bb6_00
Jan 18, 2009 06:17 AM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
24TEN
Feb 15, 2007 02:58 PM
jolt-tsp
Apr 30, 2005 12:46 PM
FritzInTN
Mar 8, 2004 11:39 PM
