my car sounds like it had a 2step
Old Aug 14, 2007 | 01:19 PM
blkekcoupe's Avatar
Default my car sounds like it had a 2step
alright so i did a complete tune up and my car is running perfectly fine...the problem is that my car sounds like a 2step when shifting...i have no clue what it could be...i was told change spark plugs...but i already have new spark plugs...i got new msd cap, msd rotor and msd wires and blaster 2 coil and ngk v power spark plugs...so i have no idea what else could be the problem
Old Aug 14, 2007 | 01:24 PM
blkekcoupe's Avatar
Default Re: my car sounds like it had a 2step (blkekcoupe)
anyone has any ideas
Old Aug 14, 2007 | 01:26 PM
4bangin92's Avatar
im sorry im new to this stuff, but what exactly is a 2step mean
Old Aug 14, 2007 | 02:12 PM
xXSilentScreamXx's Avatar
Default Re: my car sounds like it had a 2step (4bangin92)
2 step is when the car is not moving you can floor it and it will redline at what ever rpm you specify
like my 2step is set for 3500 rpm but as soon as i start moving it brings redline back up to 8k
Old Aug 14, 2007 | 07:39 PM
blkekcoupe's Avatar
Default Re: my car sounds like it had a 2step (xXSilentScreamXx)
ookkaayyy thank you for answering my problem....but yea found out what it was...i got a CEL today lik an hour ago and i checked it and its a p0420 which means its my catalytic converter or my o2 behind the cat
Old Aug 14, 2007 | 07:49 PM
93FastLs's Avatar
i had the same problem that ur having.. i had oil in my spark plug holes cause the rubber O-RINGS WERE BAD. so i threw in some gasket sealer. it stoped for about a month but now it's happening again. my cel code is throwing a crank position sensor and it's a obd1 ls ecu but the swap is a 01 LS so it's thrown the code for something totally different. cause i check the CPS.
Old Aug 14, 2007 | 08:22 PM
blkekcoupe's Avatar
i know that **** sucks but ill b iight luckily my mechanic is half a block away lol but ill try and see what it is because i was having a missfire in my 4th cylinder last week and it was because i wasnt getting contact with the rotor and the 4th cylinder pin in the cap so i changed it and now i got this p0420 code which culd be gas or oil in my spark plug so ill try and find out 2mrw what the problem is but peoples guesses are welcomed too so keep it on top
Old Aug 14, 2007 | 08:33 PM
94hondacivicvtec's Avatar
there is another thing called 2step that turbo people use. something with retarding the timing to make more pressure in the manifold to spool up the turbo for launches. it sounds like somone throughing hand grenades in your motor. Don't know all about it so if thats not all corect someone chime in.
Old Aug 14, 2007 | 08:46 PM
h22-hatch's Avatar
Default Re: my car sounds like it had a 2step (94hondacivicvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec &raquo;</TD></TR><TR><TD CLASS="quote">there is another thing called 2step that turbo people use. something with retarding the timing to make more pressure in the manifold to spool up the turbo for launches. it sounds like somone throughing hand grenades in your motor. Don't know all about it so if thats not all corect someone chime in.</TD></TR></TABLE>
thats what i call anti-lag im sure there's a more specific name for it...all that does is help the turbo build boost before you launch, basically the same thing as a 2step
Old Aug 14, 2007 | 09:11 PM
Default Re: my car sounds like it had a 2step (h22-hatch)
2step http://www.youtube.com/watch?v=j6_MwYRI9wc what you call 2step is a 2step rev limiter
Old Aug 14, 2007 | 09:30 PM
blkekcoupe's Avatar
i know what a 2step is lol i had it on my 94 4door....my coupe that i have rite now ...does not have 2step but it sounds just like it and my question is why would it sound like a 2step when it does not have 1
Old Aug 14, 2007 | 09:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkekcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i know what a 2step is lol i had it on my 94 4door....my coupe that i have rite now ...does not have 2step but it sounds just like it and my question is why would it sound like a 2step when it does not have 1</TD></TR></TABLE>
just informing others on 2setp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bangin92 &raquo;</TD></TR><TR><TD CLASS="quote">im sorry im new to this stuff, but what exactly is a 2step mean </TD></TR></TABLE>
it could be a bad coil but unlikely, or timing is messed up &lt;- most likely. check you timing with a timing light.
Old Aug 14, 2007 | 09:49 PM
EjSex's Avatar
could be an IACV problem or a TPS sensor problem
-check the wiring to each and clean out the inside of the IACV with brake parts cleaner to be safe
Old Aug 15, 2007 | 07:41 AM
h22-hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec &raquo;</TD></TR><TR><TD CLASS="quote">2step http://www.youtube.com/watch?v=j6_MwYRI9wc what you call 2step is a 2step rev limiter</TD></TR></TABLE>
lol i know what a 2 step is, id be pretty stupid to have it on my car if i didnt know what it was or how to use it
dantamparacer
Jun 28, 2012 03:46 AM
94SiSQO
Jul 15, 2002 05:36 AM
94SiSQO
Jul 15, 2002 04:05 AM
