fourth cylinder not firing
hey guys im new to this forum but i have a serious question regarding my ls,
my fourth cylinder isnt firing at all im getting gas and spark but everytime i take out the plug wire or the fuel injector clip the car doesnt run any different could i possibly have a piston ring gone or have the exhaust valves open all the time let me know what you think because i am so confused on why my car isnt runnin as fast as it should....
thanks
~~Jeff
thanks
~~Jeff
Firstly you should try and do a compression and/or leak down test if possible. If you are have no or low compression in one cylinder, the car will sound much like a Subaru.
However, are you sure the sparkplug you removed is getting spark? Make sure the wire is plugged into the dizzy very well, especially if your plug wires are aftermarket. If it seems to be plugged in fully, try taking the spark plug out and connecting it to the plug wire. Ground the sparkplug and attempt to crank the car, tell us if you can see the plug sparking?
actually now that you mention it it kinda does sound like a subaru at low rpms up until around 3500 and yea i made sure of everything the plug is sparking all the wires are tight all the injectors fire ( i know i got sprayed in the eye with gas) but i havent had the time to do a compression or leak down test yet im gonna try those friday on my day off but your the fourth person to tell me that sooo im assuming it may be a ring
thanks for the quick reply though
also just to add the motor has been in three different cars in one car it was turboed and in the other it was sprayed and in mine it just has an oil feed line for turbo ready so it could be apossiblity that it is a ring but yea i grounded the plug on the block and saw it sparkin
going to buy a compression tester later today what psi should i be looking for? and i have to disconnect the fuse to the fuel pump right so that way the car doesnt get fuel im not 100% sure on how to do a compression test honestly never done one before
I told you on your other thread...
Take spark plugs out and put compression tester in, and crank the car until the needle doesn't go anymore...
just to update all you guys that helped me out i finally got a compression tester from a good friend and i did the test today when i got out of work around 1130pm the results are.............................
1st cyl. 200, 2nd cyl. 200, 3rd cyl. 195, 4th cyl. (problem cylinder) 60!! so i did a small leak down test and no change in the pressure which im kinda happy about cuz at least i dont need pistons, but im getting a new head, headgasket, valves, cams, cam gears, and valve cover gasket. so im doin all this work this weekend. im buying the gaskets and head tomorrow and doing the work saturday will post up how it goes
