RSX-S Speakers
Old Aug 14, 2007 | 10:10 AM
justbriaN's Avatar
Default RSX-S Speakers
My speaker on the front driver side gave out on me... I want to replace the two front ones, but since its a bose system they told me i need speakers that are amplified is that true? If not what are some good speakers I could use to replace the front ones... I just know that they are 6 1/2
Old Aug 15, 2007 | 01:58 PM
david11's Avatar
Default Re: RSX-S Speakers (justbriaN)
whose "they"....i went to bestbuy and they didnt mention anything about that..
Old Aug 15, 2007 | 02:14 PM
phthalo's Avatar
GDD4LIFE
Default Re: RSX-S Speakers (david11)
don't all speakers use an amp? you can use anything
Old Aug 17, 2007 | 03:09 PM
zsudz922's Avatar
Default Re: RSX-S Speakers (phthalo)
all speakers need to be amplified if you want sounds to come from them. i am guessing you are just using the internal head unit amplifier. you can get almost any 6 1/2 size speaker and put them in. go to crutchfield.com search for car speakers and put in your car make/model and it will tell you if the speakers fit or not.
also you can post this in the Audio/Security forum if you need more help.
Old Aug 17, 2007 | 04:10 PM
JDMk20R's Avatar
You would need to get new factory Bose ones from acura. Swapping the front to after market won't work, because everything is coming from the amp, not the radio. It'll sound like ****. All of the speakers are amplified. So see if anyones selling their bose setups or just take it all out including the radio and get an aftermarket system, you're better off that way.
Old Aug 17, 2007 | 06:53 PM
Agent_EM1's Avatar
Default Re: (JDMk20R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMk20R &raquo;</TD></TR><TR><TD CLASS="quote">You would need to get new factory Bose ones from acura. Swapping the front to after market won't work, because everything is coming from the amp, not the radio. It'll sound like ****. All of the speakers are amplified. So see if anyones selling their bose setups or just take it all out including the radio and get an aftermarket system, you're better off that way.</TD></TR></TABLE>
Interesting... Did not know that..
Old Aug 17, 2007 | 09:16 PM
image976's Avatar
The bose system will only work with bose components. so if u have to change a speaker you have to change it with a bose speaker from the dealer ....otherwise you will have to buy a new head unit and bypass the amp that the bose system ran on. Bestbuy charges extra to do this cuz from wat i was told it was a pain in the ***. So really u might as well go with an aftermarket headunit ,speakers and amp. IMO its the only way to go.
Old Aug 18, 2007 | 12:02 AM
JDMk20R's Avatar
Default Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Interesting... Did not know that..</TD></TR></TABLE>
lol yessir, I was a Roadshop installer at Circuit City for 2 years
Bypassing the bose amp is pretty simple, just time consuming and I work at Nissan Part time in the Parts Dept. Nissan also has Bose systems and the cost of one damn speaker is rediculous. So I say, sell the bose crap and get yourself a nice setup within your bugdet
Old Aug 18, 2007 | 10:17 AM
JDMk20R's Avatar
PM him if you're on CRSX
http://forums.clubrsx.com/showthread.php?t=494596
Old Aug 19, 2007 | 06:48 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by image976 &raquo;</TD></TR><TR><TD CLASS="quote">The bose system will only work with bose components. so if u have to change a speaker you have to change it with a bose speaker from the dealer ....otherwise you will have to buy a new head unit and bypass the amp that the bose system ran on. Bestbuy charges extra to do this cuz from wat i was told it was a pain in the ***. So really u might as well go with an aftermarket headunit ,speakers and amp. IMO its the only way to go.</TD></TR></TABLE>
your an idiot. I just replaced my rear speakers today with ones out of my ep3 and they work.
These people do not know what they are talking about. I don't care if they were an installer for whome ever because I have sent many friends in there to buy certain things and those morons send them back with the complete opposite thing they went there for because they feel it is correct.
Anyways, if you are installing an aftermarket cd player you have to get an amp bypass harness. Truely you can just make you own as I did for the mustang I installed a mild stereo in since they forgot to order one.
As far as using stock components to amplify aftermarket speaker. Of course they aren't going to sound as good as they would if they were being powered from an amp. The amp will give them more power which will allow them to run at there rms in return giving out better sound.
The bose sound system in the rsx is complete garbage. Well not entirly. Actually it is. The sub sucks, the speakers are cheaper than ****. I stuck with the stock cd player and went with some CDT speakers. Helped out a lot. If you need more "bump" you can do the switch of the wire of the sub. There is a DIY on crsx about that. I have not done it as I really am not into the loud music big bang thing. You can also swap out the little bose sub in your trunk with another one of equal size and use an aftermarket amp.
TyLLy_4
Audio / Security / Video
Oct 15, 2009 03:21 PM
Whats_the_w0rd
Sep 10, 2006 12:24 PM
Speed_69
Mar 10, 2006 07:22 AM
00PurpleGSR
May 21, 2002 08:15 PM
RevedOut
Aug 17, 2001 11:55 AM
