H22 swap questions
If i have a 93 civic hb with a 95 h22 during the swap which i wasnt a part of would you normally swap out the fuel pump of the shell vehicle for the pump from the motor car. Appreciate any help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">you can use your stock fuel pump.</TD></TR></TABLE>
Yeah, the pump in the "shell car" as you put it will work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22ARunninHard »</TD></TR><TR><TD CLASS="quote">i dont have to worry about the stock pump not supplying enough fuel to the dif. motor</TD></TR></TABLE>
No you'll be fine.
No you'll be fine.
You won't need a new fuel pump unless you're turbocharging the crap out of the new motor...
And when that happens, the fuel pump from the donor vehicle won't do, anyways.
fastwanabe
Jul 9, 2003 04:03 AM
