no power in cabin, engine bay has power
Old Aug 13, 2007 | 10:26 PM
authentic plusONErandy's Avatar
Default no power in cabin, engine bay has power
car wont start. i was moving it back into my garage. i stalled the car died out. and when i tried to start it up again, the instrument cluster did not even light up.
all of the fuses are good.
battery tested good. all of the fuses in the engine bay has power. all getting ~12 volts.
checked the fuses inside of the car all fuses good but...none have power.
doubled checked all of the plugs/harnesses from the engine bay fuse box... everything is plugged it securely.
checked all of the harnesses under the dash. everything is in securely
.... i have no auxilary power.
no lights, no radio, no nothing...and no power = car wont start.
anybody have anything else for me to check?
edit: i just checked the 40amp and 80 amp fuse under the hood. both have clean connections.
and i checked the main relay for good measure.
still no luck
Modified by plusONErandy the orig BYS at 11:56 PM 8/13/2007
Old Aug 13, 2007 | 10:27 PM
sfgreddiedsi's Avatar
up for the plusONE guy!
Old Aug 13, 2007 | 10:38 PM
LowTEC-Derbo's Avatar
Default Re: (sfgreddiedsi)
did a rat eat your harness?
Old Aug 13, 2007 | 10:55 PM
Default Re: (LowTEC-Derbo)
it started up fine earlier in the day... i was trying to back it back into the corner and it started up fine then too. then i died out and the car shook violently and after that no power
Old Aug 14, 2007 | 09:57 AM
UP!!!!
Old Aug 14, 2007 | 10:45 AM
bump! i need a solution by 10pm!! gotta drive this unreliable piece of **** to so cal haha
Old Aug 14, 2007 | 04:45 PM
King V's Avatar
Default Re: (plusONErandy the orig BYS)
Check your grounds. You've checked for power, you gotta check the other side of the circuit. I would try to find the main cables.
Akodo
Audio / Security / Video
Jan 12, 2016 10:08 AM
Trandana
Oct 19, 2014 12:41 PM
mcleary333
Nov 30, 2013 04:39 PM
eagleclawracing
Nov 12, 2012 10:52 AM
keepitngga1
Nov 28, 2006 01:49 PM
