will having a cat help with power in a 99si?
Old Aug 13, 2007 | 06:28 PM
orangeracer's Avatar
Default will having a cat help with power in a 99si?
llike the title says will a test pipe help or is a cat worth having
Old Aug 13, 2007 | 06:29 PM
nix94delsol's Avatar
well u dont have a smog law ware u are so just gut the cat, if u get pulled over with a testpipe on it ur gunna get a ticket
Old Aug 13, 2007 | 06:35 PM
gsxr1k05's Avatar
hope you got headers and a decent exhaust if you want to see anything other than a loss in backpressure
Old Aug 13, 2007 | 06:36 PM
rebuiltSI's Avatar
Default Re: (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">hope you got headers and a decent exhaust if you want to see anything other than a loss in backpressure</TD></TR></TABLE>
And gas mileage will decrease
Old Aug 13, 2007 | 07:19 PM
doood's Avatar
been there done that
Default Re: (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">well u dont have a smog law ware u are so just gut the cat,
that's an even worse idea than a test pipe
leave your stock cat on. i doubt you're moving enough air to see the benefits of a high flow cat or testpipe.
Old Aug 13, 2007 | 07:20 PM
hows that worse? it at least looks whole if ur trying to get it inspected, even if you DID go for a test pipe ud have to yank it off and put the cat back on
enlighten me
Old Aug 13, 2007 | 07:39 PM
doood's Avatar
gutting a cat leaves a void inside it where the catalyst material was. this causes turbulence for the exhaust gases. you want them to exit the exhaust system as quickly as possible.
Old Aug 13, 2007 | 07:43 PM
highrev1987's Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">gutting a cat leaves a void inside it where the catalyst material was. this causes turbulence for the exhaust gases. you want them to exit the exhaust system as quickly as possible.</TD></TR></TABLE>
truth
and latter down the line if you want to sell the car or pass inspection you have a bum cat and you are SOL
Old Aug 13, 2007 | 08:22 PM
b16a3delsol's Avatar
Default Re: (highrev1987)
buy a test pipe then. Drive like you have some sense and change it once a year to get inspected. It probably wont help much anyhow but who am i to say.
blks2k3
Nov 11, 2005 04:57 PM
JDMcivicRacing
23
Jun 29, 2005 10:10 AM
Boring
Jan 1, 2005 04:31 PM
sshaikh01
60
May 10, 2004 04:26 PM
b16_madman
28
Sep 26, 2003 08:00 PM
