Bore size increase, any real gains?
Old Aug 13, 2007 | 04:08 PM
swappedcx's Avatar
Default Bore size increase, any real gains?
I have the typical ls/vtec setup going on. The block is going to get sent out for sleeving, but im undecided on a bore size and have yet to get pistons. Is there any real difference vs spool times or power gains from slightly increasing the bore size? I do not want to go to 84mm in fear of having a issue with the motor and making the sleeves thinner on the next rebuild/ re-bore. Would there be any gain at all to increase to a 82mm or around there from the 81mm stock?
Old Aug 13, 2007 | 07:29 PM
doood's Avatar
been there done that
Default Re: Bore size increase, any real gains? (swappedcx)
more displacement is always good especially if you're trying to spool a relatively big turbo. 82mm or 83mm is good if you want room for future overbores.
W!d3b0dYr3X
Mar 15, 2012 10:40 AM
beasty=eg
Aug 29, 2008 09:24 PM
penjaja
Mar 23, 2003 08:17 PM
lysergican
May 30, 2002 06:42 PM
