I FORGOT A WASHER!!!
i changed my oil and forgot the washer
ill be ok right ..... i made sure it was really tight
my friend thinks im gonna leak oil everywhere but it has been good for like 3days
just curious
just curious
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k powered ej1 »</TD></TR><TR><TD CLASS="quote">sigh </TD></TR></TABLE>
Wheres the tech in that statement?
OP- I dont think thats te best idea to keep it that way. The crush washer is there for a reason-If i were you, id get a few peices of cardboard, and some computer printer paper peices, and in yourdriveway lay them down and run the car for say 10 minutes, and then let it sit for a few hours, and see if tehres any drips./ if the bolt loosend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">i changed my oil and forgot the washer
ill be ok right ..... i made sure it was really tight</TD></TR></TABLE>
The entire point of the aluminum crush washer is to protect the threads in the oil pan from wrench-wielding airheads.
"Really tight" is not a torque spec.
The drain plug is supposed to be torqued to 31 lb-ft. No more, no less.
Guest
Posts: n/a
im well aware about his constant posting after buying the car- but that doesnt mean you have to belittle him. simply report it to a moderater if you feel the post isnt necessary. stop trying to be a ethug.
Targa- i never knew thats what the crush washer was for - i thought it actually had some sort of sealing property. I know there like ten cents each, but in theory you could just put the bolt in and torque it to 31lbs and itl be set?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k powered ej1 »</TD></TR><TR><TD CLASS="quote">i torqued down my main bolts to really tight, will it hold?
I dunno, one or two of my rod bolts seemed to hold okay when I tightened them to "really tight" . . .
I forgot to put in the rod bearings though. But they haven't spun yet, so I guess I'm okay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">in theory you could just put the bolt in and torque it to 31lbs and itl be set?
Until you pull the threads out of the pan and have to lay on your back in the mud at the junkyard, picking a used oil pan . . .
</TD></TR></TABLE>I dunno, one or two of my rod bolts seemed to hold okay when I tightened them to "really tight" . . .
</TD></TR></TABLE>Until you pull the threads out of the pan and have to lay on your back in the mud at the junkyard, picking a used oil pan . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">just get a new oil drain plug for ***** sake
reading owns u
see i forgot it not lost it !!!
i have it but, i just put in the new oil *ie- thats y i removed the drain plug.*
and forgot to put it on there
i was just wondering if it will hold seeing as i dont have a jack and my cars lowerd
so it was a lil difficult changing it the 1st time.... rather just leave it till the car runs
reading owns u
It will hold, but definitely seep oil. Even just reusing the old one will cause so seepage. Customers come in all the time after having their oil changed at Jiffy Lube or Valvoline where they reuse them and they are almost always seeping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
The entire point of the aluminum crush washer is to protect the threads in the oil pan from wrench-wielding airheads.</TD></TR></TABLE>
It helps the drain plug keep an oil tight seal, just like fuel filter crush washers keep the lines from seeping. Tight seal is the entire point of the washer there buddy.
invisible
21
Dec 27, 2006 08:27 AM
