rex was smokeing so i took off my head.
Old Aug 13, 2007 | 11:25 AM
hazrd420's Avatar
Default rex was smokeing so i took off my head.
ok well my a6 was smoking so i tryed everything i could think of with out taking the head off. Know i got i it off and i could see in side of the head there was oil driping down the valve. Like if it was all built driping toward the piston. what would cause this..
Old Aug 13, 2007 | 12:05 PM
SIred91's Avatar
Rainman
Default Re: rex was smokeing so i took off my head. (hazrd420)
If you dont know that.....you shouldn't be taking the motor apart. BUT.....you should replace the valve stem seals and the valve guides.
Look into a shop doing a whole valve job for you, then put it back together.
Good luck.
Old Aug 13, 2007 | 12:07 PM
cbp_crx's Avatar
Default Re: rex was smokeing so i took off my head. (SIred91)
I totally agree, at least have a service manual handy, if you are going to tear your engine apart, if you don't know what your doing. I would also say it is the valve stem seals.
Old Aug 13, 2007 | 01:17 PM
hazrd420's Avatar
Default Re: rex was smokeing so i took off my head. (cbp_crx)
yea i was going to take it to get to get a three angle job done . like i tell everyone i dont know everything but i do know alot.. Thanks though i was going to replace the rods pistons and all the good stuff. I was wanting to go honda can i put some from a diffrent motor or does it have to be a6?
Old Aug 13, 2007 | 08:29 PM
hazrd420's Avatar
bumpola!
dominate9
Apr 14, 2020 02:10 PM
JDMDC4life
Jul 20, 2014 11:58 AM
SYN4DRDX
Jul 9, 2005 12:09 PM
biggie2005
Feb 26, 2004 06:23 PM
fe519
Dec 27, 2002 12:50 PM
