Is transmission bracket mount really necessary? PIX Inside
Old Aug 13, 2007 | 05:03 AM
crazyguy's Avatar
Default Is transmission bracket mount really necessary? PIX Inside
the car is a eg hatch with b16a and b16a tranny swap
after i have done the swap.i dont install that bracket (#15 and #12 and #19 show in the pic below)
the reason i dont install it back on is because one of my friends said that bracket is not really necessary.i thought it is there for a reason otherwise honda would not have designed it.
so.do u guys have it installed or it is not really necessary and what does that backet do acutally?cause the car is already got a tranny mount.
and also i dont install the ac bracket side either.(#18 and #14)
Old Aug 13, 2007 | 05:34 AM
Civichx1998's Avatar
Default Re: Is transmission bracket mount really necessary? PIX Inside (crazyguy)
They are Tourque Mounts and yes you need them. They help support the engine and not let it move under heavy loads back and forth.
Old Aug 13, 2007 | 05:36 AM
EE_Chris's Avatar
I love playing Jenga with my Civic. Just keep removing stuff until the engine falls out. When it does, then you'll know not to remove the last piece that you did.
What kind if logic are you using over there anyway? You already thought it was there for a reason otherwise Honda wouldn't have designed it, but you go ahead and decide against using it anyway? I see.
Old Aug 13, 2007 | 05:48 AM
usdmEHboy's Avatar
Default Re: Is transmission bracket mount really necessary? PIX Inside (EE_Chris)
i dont use mine...with the hasport mounts you do not need to have them
Old Aug 13, 2007 | 05:49 AM
Luserkid's Avatar
The only reason to take off those mounts/brackets is if your going to being using solid mounts. If your not i suggest putting them on.
Old Aug 13, 2007 | 06:51 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
yes !
Old Aug 13, 2007 | 07:05 AM
instrument's Avatar
Civic type JENGA
"WoRd Yo DiS **** is Teh HaWT"
next start removing lug nuts, who needs four!!!
Old Aug 13, 2007 | 07:13 AM
spoolin69's Avatar
you dont have to run them if you got hasport but you should run them if you dont have hasport
couse the motor will jerk
Old Aug 13, 2007 | 07:22 AM
crazyguy's Avatar
thanks to yall... !!!
i will put those mounts on tonight
Hatch_Kid
13
Dec 31, 2012 06:22 AM
Boosted_JDM
Apr 9, 2007 03:45 PM
XkjeldorX
Jun 21, 2006 01:49 PM
GSRinmyCRX
Mar 22, 2005 04:11 PM
Boost2NA
Aug 19, 2002 02:56 AM
