Need to put a/c belt on can anyone help? for a 92 ex civic sedan
Old Aug 12, 2007 | 09:08 PM
kit50si's Avatar
Default Need to put a/c belt on can anyone help? for a 92 ex civic sedan
Can anyone tell me how can a belt pop out of place. Because I checked it last week and was lodged in between the other belts no wonder the a/c just stop working one day. Just need the write up to put it back on lost my big chilton book. tnx
Old Aug 12, 2007 | 09:18 PM
Nickboxer7's Avatar
Default Re: Need to put a/c belt on can anyone help? for a 92 ex civic sedan (kit50si)
if the belt is still on it shouldnt be hard at all. Just make sure the tensioner is still there and put the belt around the a/c pulley, tensioner, and the third pulley a little past the tensioner. If the belt is off then you need to get it around a mount first.
Once you have it on the three pulleys just tighten the bolt on the tensioner, which is directly on top of it going down, and it should tighten the belt. O yeah, you will have to loosen that and possible the nut on the tensioner to drop it down enough to slide the belt on.
I hope this makes sense, b/c its late right now lol.
Old Aug 12, 2007 | 10:17 PM
kit50si's Avatar
Default Re: Need to put a/c belt on can anyone help? for a 92 ex civic sedan (Nickboxer7)
I had cut if of because it was mangled by the other belts.
Old Aug 14, 2007 | 09:31 AM
Nickboxer7's Avatar
Did you get it back on now?
phat00civic
Mar 7, 2012 06:30 AM
JMod
16
Jun 23, 2005 11:49 AM
Threads
Oct 8, 2004 12:37 PM
SpoolnG2
Dec 16, 2002 04:53 PM
J T*
14
Apr 5, 2002 06:21 PM
