auto to manual i searched
Old Aug 12, 2007 | 08:36 PM
95civiccpdx's Avatar
Default auto to manual i searched
i cant seem to find an auto to manual tranny mount for my 95 civic dx i want to put in a b18a1
Old Aug 12, 2007 | 08:44 PM
Old Aug 12, 2007 | 08:47 PM
any body?????????
Old Aug 12, 2007 | 09:00 PM
DestructoEH's Avatar
Default Re: (95civiccpdx)
You can use the Innovative Auto-Manual mount for a Civic with both the d-series and b-series hydro trannys. I'm pretty sure the Hasport mount is the same way.
Old Aug 12, 2007 | 09:20 PM
sageuvagony's Avatar
Default Re: (DestructoEH)
Good luck paying almost 200 bucks for it.
Old Aug 12, 2007 | 09:29 PM
TheLastSpartan's Avatar
Default Re: (sageuvagony)
Yea, Innovative can make some. I got mine for less then $200 though... around $100-something shipped. I haven't put it on yet or otherwise I'd be more informative about it.
Old Aug 12, 2007 | 10:09 PM
xxjdmek9xx's Avatar
Default Re: auto to manual i searched (95civiccpdx)
why do i hear that when you do a auto to manny swap.car never is the same at all.
Old Aug 13, 2007 | 12:27 AM
k powered ej1
Guest
Posts: n/a
Default Re: auto to manual i searched (xxjdmek9xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxjdmek9xx &raquo;</TD></TR><TR><TD CLASS="quote">why do i hear that when you do a auto to manny swap.car never is the same at all.</TD></TR></TABLE>
becuase you have to shift it
Old Aug 13, 2007 | 06:00 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k powered ej1 &raquo;</TD></TR><TR><TD CLASS="quote">
becuase you have to shift it </TD></TR></TABLE>
So true
The swap is really straight forward and the car will be as good as the installer. I have never had a problem with any of my auto to manuals that i do for people, i have never had a car where it wouldnt drive straight or anything like that.
Hasport for the mount
Old Aug 13, 2007 | 06:06 AM
luckii's Avatar
theres no problems. u just have to know how to shift. its not complicated to do the conversion. just have to get linkage, shifter, console from a junk yard.
Old Aug 13, 2007 | 06:16 AM
crazyguy's Avatar
u will need some parts to make the conversion
first of all u need the tranny mount..either get a conversion mount or have the bracket rewelded.
second u will need pedals.shift linkage(include bushing).shifter.manual ecu. u might be able to use your auto ecu but there is a chance of getting check engine light.
third. u will need slave clutch cylinder...and if the manual tranny u get comes with clutch and presure plate.
good luck with the swap.
scott_kusch
Mar 31, 2008 09:40 AM
ProjectBoosted
Aug 22, 2007 01:01 PM
niceguyjp2183
Apr 5, 2006 04:19 PM
DB82NR
Apr 2, 2006 04:16 PM
pK1spooled
Dec 16, 2005 11:26 PM
