Balance shaft timing marks
On the forward balance shaft, there's an obvious timing mark on the shaft itself. On the rear, remove the sealing bolt and insert an M6x100mm bolt to lock the balance shaft in place. You can tell when you have the balance shaft in the right spot. When you insert the 6mm bolt, it'll only move a few degrees in each direction. The Helms manual shows exactly what you need to do.
One of the best things that you can do is download a pdf of the shop manual for your car. It will give you all of this info and more, step by step instructions, torque specs, any special tools needed etc.
woukd I just be able to take that bolt out and the gear and than slip on the balance shaft seal? Is TDC needed to do this?
thanks a lot I’m in a pickle!
