Balance shaft timing marks
Hello what notches do I use to line up the balance shaft timing belt on a h22a4 motor?
Re: Balance shaft timing marks (408sbfmustang)
On the forward balance shaft, there's an obvious timing mark on the shaft itself. On the rear, remove the sealing bolt and insert an M6x100mm bolt to lock the balance shaft in place. You can tell when you have the balance shaft in the right spot. When you insert the 6mm bolt, it'll only move a few degrees in each direction. The Helms manual shows exactly what you need to do.
on the fwd shaft use the notch with the white make
what one is the sealing bolt
1 Attachment(s)
the sealing bolt is on the back of the block, it has a 12mm head.
Be careful with the front shaft, there is an arrow on the oil pump and a line on the pulley, but they're not at the top here's a pic. Attachment 491192 |
On the 5Gen (H22A4), the timing mark is on the top side balance shaft itself. There is a corresponding mark on the oil pump housing. Reference page 6-18 in the 97-99 Helms manual.
Thanks for sharing that info! I was about to ask, since I’m working on my h22a4 now.
Originally Posted by FreddyH22A
(Post 52019455)
I’m working on that now thanks!
Originally Posted by snobordboy
(Post 52020054)
One of the best things that you can do is download a pdf of the shop manual for your car. It will give you all of this info and more, step by step instructions, torque specs, any special tools needed etc.
woukd I just be able to take that bolt out and the gear and than slip on the balance shaft seal? Is TDC needed to do this? thanks a lot I’m in a pickle! |
