Mystery LSD? (pics)
Old Aug 12, 2007 | 03:49 PM
BIGTUNA's Avatar
Default Mystery LSD? (pics)
If anyone knows what LSD this is let me know. I bought it from a local trans shop who had it sitting on the shelf for many years. It bolts up to 92+ D-series ring gear and fits perfectly in the the case. No clearance or shimming issues. The passenger side of the diff fits a B series axle and the drivers side of the diff has large splines and no groove cut for a axle lock ring. I tried a Bseries half shaft and it slides in and works perfectly. So it fits a 92+ D ring gear yet accepts only B series axles and half shafts. Im thinking its maybe a ZC diff if a ZC half shaft has the same splines and the same size as a B-series half shaft. The speedo ring gear is a odd color too, usually honda's are black from what I have seen.
So if any one knows the MAKE (OEM,Kaaz, OBX ect) and what the right APPLICATION for this diff let me know.
Thanks
Modified by BIGTUNA at 10:56 PM 8/13/2007
Old Aug 12, 2007 | 06:32 PM
4g hatch's Avatar
i think the zc's halfshaft have the same splines as a b series. that looks like a oem speedo gear. some of the zc's came with oem lsd. im not sure if there interchangeable between cable and hydro,but u could probably just use your final drive
4g hatch's Avatar
also how much did u pay,looks like a good find
Old Aug 12, 2007 | 07:21 PM
BIGTUNA's Avatar
Default Re: (4g hatch)
The shop installed it in my trans (s20 del sol trans), but during the install into the car I had the axle issue. I swapped the diff out today for a stock diff, now just trying to figure out what it is so I can sell it or use it down the road.
Old Aug 12, 2007 | 10:09 PM
locash's Avatar
Default Re: (BIGTUNA)
It appears to be an OEM Honda differential from a single cam car that came with an intermediate shaft, almost definately from a JDM application, most likely an EF wagon?
Old Aug 13, 2007 | 10:51 AM
havok hybrid's Avatar
Default Re: (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">It appears to be an OEM Honda differential from a single cam car that came with an intermediate shaft, almost definately from a JDM application, most likely an EF wagon?</TD></TR></TABLE>
I beleive it is a 86-89 ZC LSD . They did you a half shalf always.
Old Aug 13, 2007 | 01:05 PM
Bense's Avatar
Default Re: Mystery LSD? (BIGTUNA)
I don't think that it's a zc lsd, because why would it have the axle size as the d-series for the drivers side
for the record, zc diff = si differential with cable b16a side gears.
Old Aug 13, 2007 | 01:45 PM
BIGTUNA's Avatar
Default Re: Mystery LSD? (Bense)
EDIT Some how I got a B series passenger axle mixed in with my spares, BOTH side of the diff take B series axles yet the ring gear fits a D
r8byb
Jul 29, 2011 10:16 AM
GSR4U2NV
Oct 9, 2006 07:03 AM
rice is nice
Dec 13, 2004 09:26 AM
crxcess
32
Aug 5, 2003 07:20 AM
