question about stock 2000 honda civic rims
Old Aug 12, 2007 | 12:34 PM
darksolderx's Avatar
Default question about stock 2000 honda civic rims
ya, so i when i bought my car (about 2 months ago) it came with hubs so i figured it was never bought with the stock rims and i just recently(last night) got my hands on some stock civic rims for the year 2000 same year as my car, and when i put them on i tightened all the lugs and then i brought it to fill the tires with air. BUT i noticed while i was driving the front 2 wheels were making this terrible grinding noise as if the rim was rubbing against the brake caliper
so my question is any hints or tips to reduce the damage or anything???
Old Aug 12, 2007 | 12:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: question about stock 2000 honda civic rims (darksolderx)
Have you taken the wheels off and checked to see where the grinding is occurring?
Old Aug 12, 2007 | 12:44 PM
cmiller219's Avatar
should have no problem with them rubbing? is ur car lowered because ur new rims are bigger. but i think there may just be something small rubbing that maybe u bent or fell it the way of the rim travel just jack ur car up in the front put it in nuetral and spin each tire to find out which one is making the noise and then go from there.
Old Aug 12, 2007 | 01:35 PM
well hmm the thing is while i was driving to get them filled it seemed as if the grinding began to get less as they rubbed more, and now it can kinda almost barely hear it but i can "FEEL" the rubbing which is kinda weird
Old Aug 12, 2007 | 01:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: (darksolderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darksolderx &raquo;</TD></TR><TR><TD CLASS="quote">well hmm the thing is while i was driving to get them filled it seemed as if the grinding began to get less as they rubbed more, and now it can kinda almost barely hear it but i can "FEEL" the rubbing which is kinda weird</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Have you taken the wheels off and checked to see where the grinding is occurring? </TD></TR></TABLE>
Old Aug 12, 2007 | 01:55 PM
cmiller219's Avatar
did u paint the brake calibers when u took the rims off. if so u could have goten paint on the roters and its just wearing off . but yeah jack it up spin each wheel and find out where its coming from
hmm nope ill have to do that in a couple of minutes tho its killer hot outside
Old Aug 12, 2007 | 02:57 PM
@cmiller219 well see ino where its coming from its coming from the front 2 wheels, but i cant understand why, theres nothing under it, they are stock rims so they shouldnt be any bigger or smaller than my hubcaps i had, so i just dont understand why im getting the sound btw i hear it BAD when im turning
Old Aug 12, 2007 | 03:01 PM
sageuvagony's Avatar
Narrow it down.
Old Aug 12, 2007 | 05:06 PM
ok i did some investigating my neighbor says its my cv joints
Old Aug 12, 2007 | 05:11 PM
I don't see how that could have anything to do with the rims.. Maybe your CV joints are rubbing against the rims just like my back bumper rubs against my windshield.
Old Aug 12, 2007 | 05:12 PM
GG99's Avatar
um saying you have 2000 civic rims dont help at all. do you have a picture of them?
*edit - do they look like this?
Old Aug 12, 2007 | 05:54 PM
yes they look exactly like that
Old Aug 12, 2007 | 06:21 PM
GG99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darksolderx &raquo;</TD></TR><TR><TD CLASS="quote">yes they look exactly like that</TD></TR></TABLE>
the rim is rubbing against the brake caliper, making the grinding noise.
you can either run a spacer so it clears, or grind down the calipers a bit for clearance.
Old Aug 12, 2007 | 06:30 PM
no, sry i didnt clarify earlier i lifted the car and put it in neutral along with ebrake and began spinning the wheel and at no time did it make the noise EXCEPT when i turned the wheel all the way to the side then it started to make the noise.(plus the rim JUST clears the caliper only by like 1 or 2 cm tho lol but its not hitting it, and if it is its grinding down so ohwell)
Old Aug 12, 2007 | 07:58 PM
EM1SON's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darksolderx &raquo;</TD></TR><TR><TD CLASS="quote">no, sry i didnt clarify earlier i lifted the car and put it in neutral along with ebrake and began spinning the wheel and at no time did it make the noise EXCEPT when i turned the wheel all the way to the side then it started to make the noise.(plus the rim JUST clears the caliper only by like 1 or 2 cm tho lol but its not hitting it, and if it is its grinding down so ohwell)</TD></TR></TABLE>
you need to change your axles. This happen to me before. so yeah change your axles, the problem solved.
Old Aug 12, 2007 | 08:46 PM
Johnny Ricer's Avatar
Default Re: (EM1SON)
It could also be your dust shield rubbing
Old Aug 13, 2007 | 12:30 AM
k powered ej1
Guest
Posts: n/a
Default Re: (GG99)
those are known as hx wheels they are too small for your car, they dont fit ex rims without rubbing grab the angle grinder man
Old Aug 13, 2007 | 04:43 AM
.... now that i think about it the rims didnt exactly come from a 2000 civic im pretty sure it was a hx so i think that mite be the problem
Old Aug 13, 2007 | 11:30 AM
k powered ej1
Guest
Posts: n/a
they make 2000 civic hx's you know that right?
the whells are too small for your brakes, the 99-00 civic SI wheels bolted to your car
chase7687
Acura TL, RL & ZDX
Sep 17, 2012 10:23 PM
ge_itr
Honda S2000
Feb 26, 2007 01:56 AM
doggworld1233
30
Jul 19, 2006 08:59 PM
gangstacracka
Jul 13, 2005 07:50 PM
